Aldon Distributor
2 replies to this topic
#1 Kevybmini
Kevybmini
  • 87 posts
Posted 17 March 2024 - 06:15 PM
So today’s question. Just fitted an Aldon distributor - previously an old A+ electronic one. I’ve just noticed it must be ballast wiring as it’s 9v. I’m presuming it should be 12v ?
Also the 3ohm coil has dies after 20 miles (also new)
#2 timmy850
timmy850
  • 3,341 posts
  • Local Club: MITG
Posted 17 March 2024 - 11:12 PM
The electronic module in the distributor normally needs 12v, although Aldon should have an instruction sheet
The coil itself needs to be a matched system for the voltage and coil
1.5 ohm coil + ballast wire
3.0 ohm coil and 12v
Some electronic ones with variable dwell can run a 1.5 ohm coil with 12v, but best to check with Aldon to see if this will work for you
#3 Kevybmini
Kevybmini
  • 87 posts
Posted 18 March 2024 - 08:50 PM
Checked with Aldon, 12v wire been run in today :)
