Should I Be Worried If Oil Is Over Filled?
Posted 19 March 2024 - 06:48 PM
I'm only just learning how to do maintenance because I usually rely on my brother but I'd like to start doing things myself so apologies if this is a stupid question.
Posted 19 March 2024 - 07:06 PM
Things to remember. After driving leave the car for about 5 mins before checking the level.
hot oil is uncomfortable so if you are going to drain some oil do it with a cold engine.
check your dip stick. Is it correct many of the fancy ones slip on the alloy stop so can read as over filled when they are not.
over filling can cause issues but in this case you seem fine.
Posted 19 March 2024 - 07:30 PM
Posted 19 March 2024 - 08:35 PM
Posted 20 March 2024 - 07:01 AM
Generally 20w 50 is the grade of oil suggested and 5 litres is required if full oil filter has been changed also.
The garage have provided a service and if it is not up to scratch then your well within your rights to ask questions of their work. Or just avoid the garage completely and get your brother round and sure he would assist with dropping the oil to checkmthe amount for your piece of mind more than anything..
Welcome to the learning curve that is mini ownership.
Posted 20 March 2024 - 08:16 AM
1.5cm is probably fine. I think I've overfilled mine by that much in the past. I think there is a theoretical risk of blowing some seals or something if there's way too much. Drive normally and it will go down with time, especially if you forget to put the oil filler cap back on :)
Posted 20 March 2024 - 11:49 AM
What transmission is it?
