Glass Fuse Boxes
Posted 24 March 2024 - 11:44 AM
Does anyone have a link to a good quality original spec fuse box?
Posted 24 March 2024 - 02:32 PM
https://www.minispar...|Back to search
Posted 24 March 2024 - 04:34 PM
I found even in the originals, the fingers that hold he fuses in place don't have a lot of pressure on the fuse and the later ones even worse. This makes for a high resistance connection here that gets warm, making matters worse, then they get hot and nothing works.
Unless you're doing a period restoration, I'd suggest considering going to a different fuse box. I find the Blade Fuses good and have converted most of my cars to that.
Posted 24 March 2024 - 04:45 PM
There still are some "genuine" Lucas 2 fuse boxes advertised on a well known search engine.
Probably the quality will not be as was, as nothing is, but they are "Lucas" and not a spurious make.
Posted 24 March 2024 - 08:55 PM
This is from Minispares. I have used one and looks the same as the original.
Yep this one works fine,
Posted 24 March 2024 - 10:52 PM
I might have an original I took out.
Posted 25 March 2024 - 01:33 AM
Which type?
Posted 25 March 2024 - 02:33 AM
Posted 25 March 2024 - 11:58 AM
I may just be lucky but I have never had a problem with the glass fuses or holders, I do check nd rotate them regularly to keep clean.
also apply petroleum jelly to end of fuse and connections behind fuse box. helps stop corrosion
Posted 25 March 2024 - 01:10 PM
Great idea, I will do!
As an update I have diagnosed it as a poor connection...
The car would intermittently have no indicators, no horn and no heater lol, I just removed and refitted the fuse (was still good).
I have a new one ordered from Minimine via Ebay so I'll wait and see 😁
Cheers for the advice lads
Posted 25 March 2024 - 01:15 PM
also apply petroleum jelly to end of fuse and connections behind fuse box. helps stop corrosionI may just be lucky but I have never had a problem with the glass fuses or holders, I do check nd rotate them regularly to keep clean.
regularly had these intermittant faults and spinning fuses cured it a good idea to do ones behind air filter and bullet connectors behind grill too
