Front Drive Shaft
8 replies to this topic
#1 propjock
propjock
  • 49 posts
Posted 24 March 2024 - 10:05 PM
I am in the process of re installing my front drive shafts. I watched a video that said to rotate the drive shaft every once in a while while torquing the bolt and another video that said to use engine spacer to seat the brings and then use the required spacer to you’re the bolt down.
What kind of spacer are talking about, better yet what size spacer should I look for
#2 nicklouse
  • 18,998 posts
Posted 24 March 2024 - 10:51 PM
If you have seated the bearings correctly you don’t need to use any spacer. No need to rotate anything if it has been fitted correctly. MiniSpares list the spacer.
#3 68+86auto
68+86auto
  • 1,344 posts
  • Local Club: Queensland Mini Car Club
Posted 25 March 2024 - 01:30 AM
Is it the disc brake CV nut that you are talking about?
#4 propjock
propjock
  • 49 posts
Posted 25 March 2024 - 06:45 AM
I am talking about this thing. They want $18!” For shipping
#5 Earwax
Earwax
  • 577 posts
Posted 25 March 2024 - 07:37 AM
I am pretty sure that washer is not a spacer. It is used to 'torque ' the wheel bearings and then removed prior to torquing hub conical washer and hub nut and split pin. see Minispares site TOOL21 for explanation.
#6 nicklouse
  • 18,998 posts
Posted 25 March 2024 - 07:48 AM
Not needed if you assemble the bearings correctly.
#7 Lplus
Lplus
  • 990 posts
Posted 25 March 2024 - 10:34 AM
The idea of torqueing with a flat washer first is to seat the bearings tightly before fitting the tapered split washer.  The tapered split washer can grab the drive shaft before the bearings are fully loaded and tighly in place.  At least that's the theory.
#8 68+86auto
68+86auto
  • 1,344 posts
Posted 25 March 2024 - 12:13 PM
The dimensions aren't critical but you likely won't find something suitable on a shelf. At the price they are I bought one, I did make a quick one on a lathe when I couldn't wait.
#9 Spider
  • 15,684 posts
Posted 25 March 2024 - 07:20 PM
I've never used the flat washer nor found a need to use it.
Before assembly, check the fit of the tapered (conical) washer for fit on the CV first. Even if one was to use the heavy flat washer first and then fitted the tapered washer after, if it's not the right fit any 'good' torquing them up first with the flat washer will have been lost.
I did a write up covering many of the finer and often overlooked points on assembling the wheel bearings, including this detail, here;-
https://www.theminif...wheel-bearings/
One detail that I haven't included in the write up though, is when greasing the bearings, (or following that), is to wipe totally clean the mounting faces of the bearing and spacer of all grease. When the faces have any grease on them, it only lets them slide on each other, eventually leading to chaffing and flaring of the spacer and grooving of the CV or Drive Flange.
