Dipsticks!
Posted 25 March 2024 - 11:20 AM
Posted 25 March 2024 - 11:30 AM
Posted 25 March 2024 - 11:42 AM
Posted 25 March 2024 - 12:24 PM
Grind/file a flat on your shiny one - works a bit better then.
A and A+ dipsticks aren't quite the same as the A+ had the seal on that the A didn't. Although fundamentally they are calibrated the same from their stop point to the marks.
Posted 25 March 2024 - 12:38 PM
A series have a tube that goes below the oil level. A+ fits directly in the block, hence the seal to try & stop blow-by.
Posted 25 March 2024 - 05:35 PM
My dip stick does not hit the oil anymore.........
anyone know where I can get a longer one?...
(Joking- this actually happened when I worked in Halfords)
Posted 25 March 2024 - 05:39 PM
I need to find a longer one.
Here you go - 6 foot should just about do it
DipStick Pro™ 6 foot Extension - Drain-Net Technologies (drain-tech.com)
Posted 25 March 2024 - 05:44 PM
Interesting you should say that. What if you change the oil, put 5 litres in and the level is not showing on the dipstick....
Posted 26 March 2024 - 06:38 AM
I have been called a 6 foot dipstick before...
Posted 26 March 2024 - 09:51 PM
I had the same problem with my stainless dipstick, even after grinding, filing and milling a flat on it, So I ended up milling little pockets like modern dipsticks as in my photo, the text isn't a requirement for it to work...
Posted 26 March 2024 - 11:03 PM
You could market that. I'd buy one!!
