Oil Pressure Issue
18 replies to this topic
#16 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 01 April 2024 - 08:11 AM
I had a similar issue years ago, it turned out to be a cracked T piece. Hair line crack in the brass T piece that houses the oil pressure guage and the oil pressure switch.
#17 UnKnowledgeableMiniDriver
    Just On Tickover
  • 7 posts
Posted 01 April 2024 - 09:28 AM
I prefer to trim the gasket around the o-ring groove - that’s how the original BMC gaskets were. However I doubt this is your problem.
When you’re looking for oil pressure each time - is this by turning over on the starter or with the engine running?
If with the starter how long are you trying for - it will take some time even if you previously had pressure.
Turning over on starter for a good 30 to 40 seconds. I tried letting it run for about 4 seconds and there was still no oil pressure.
Edited by UnKnowledgeableMiniDriver, 01 April 2024 - 06:12 PM.
#18 UnKnowledgeableMiniDriver
    Just On Tickover
  • 7 posts
Posted 01 April 2024 - 09:29 AM
I'll inspect that and anything else but I'd guess I'd see an oil leak from that piece when I'm running with oil pressure, wouldn't I?
#19 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 01 April 2024 - 09:33 AM
Yes you would have thought so, but mine didnt seem to leak, but presummabley let air in, or sucked air, as a result I removed the T piece, installed the oil pressure guage on its own, and all seemed fine, then installed the switch on its own all seemed fine, installed a new T piece making sure to only do it up as tight as necessary, and all was fine after that, though I do agree with what you are saying...
