Stub Axle Reverse Thread
Posted 31 March 2024 - 10:07 AM
Posted 31 March 2024 - 11:37 AM
i guess someone in the past has fitted the same stub axle to both sides which means the side with wrong thread direction is more likely to become undone in use...therefore removing the extra 'safety factor' that was built in at the factory production line.
Radius Arm Stub Axle - Left hand:-
https://mcr.minispor...-stub-axle.html
Radius Arm Stub Axle - RH:-
Quote: "Be careful when ordering as each side has a different thread."
Edited by mab01uk, 31 March 2024 - 11:42 AM.
Posted 31 March 2024 - 12:03 PM
Posted 31 March 2024 - 06:40 PM
The reverse thread is really just an added 'safety factor' which may have been omitted in some factory production or maybe during a factory parts shortage. As long as the castle hub nut is torqued up correctly and a split pin fitted it is unlikely you will have any problems. Especially on a low mileage classic car which is easy to do diy maintenance checks on occasionally.
