Hole In Rear Subframe
8 replies to this topic
#1 minicooperr
minicooperr
  • 277 posts
Posted 01 April 2024 - 12:22 PM
I think I know the answer here but I assume this rear subframe is knackered, I have just had it sand blasted and powder coated but when fitting it I noticed this hole, any advise
#2 Ethel
  • 26,576 posts
Posted 01 April 2024 - 01:04 PM
There are repair sections, but if that's like that, is the rest good enough to justify the effort?
#3 mab01uk
mab01uk
  • 12,922 posts
Posted 01 April 2024 - 01:32 PM
MK1/2/3 Subframe Bottom Arm Repair Panel:-
https://www.magnumcl...pair-panel.html
Edited by mab01uk, 01 April 2024 - 01:32 PM.
#4 minicooperr
minicooperr
  • 277 posts
Posted 01 April 2024 - 02:28 PM
The rest of it does seem fine, I’ll have to find someone who can go about fitting the repair panel
#5 mbolt998
mbolt998
  • 433 posts
Posted 01 April 2024 - 02:44 PM
You could just weld a bit of plate over it so long as you do a good job and use metal of the right thickness.
#6 KTS
KTS
  • 2,490 posts
Posted 01 April 2024 - 02:53 PM
subframes in that area tend to rot from the inside out as crud collects between the panels above, so i would have a good poke about (with a sharp screwdriver!) at the sections above (and the same area on the other side) to find out just how solid it is.
#7 minicooperr
minicooperr
  • 277 posts
Posted 01 April 2024 - 03:53 PM
I might be better of replacing it then are the magnum subframes any good?
#8 Homersimpson
Homersimpson
  • 851 posts
Posted 01 April 2024 - 04:35 PM
I'm surprised the shotblasters powder coated it looking like that. It could be repaired but it would probably be better to replace with new unless the car is just being repaired to keep it on the road.
#9 Bobbins
Bobbins
  • 1,525 posts
Posted 01 April 2024 - 05:47 PM
I bought a powder coated rear subframe from Bull Motif for £295 delivered (my old one was bent) and it’s an excellent quality product. I’m not sure I’d go to the trouble of having a rotting subframe welded if it might fail again in a few years.
