Trying to trace the cause of oil on my clutch.
Engine is an A+. Gearbox and tx-case are pre-A+ direct/remote. Clutch is Verto. Primary gear is MiniSpares C-22G1053 . The entire unit was rebuilt (but by me) 600 miles ago. The clutch oil seal looks fine and there's no indication of oil on the back of the transfer case to suggest a leak there. But there is oil on the splines and on the friction surfaces.
Crankcase has two breathers which are tee'd together and connected to the carb - so (hopefully) crankcase pressure isn't the problem.
I can feel plenty of sideways slop (not end-float) in the primary gear on the crankshaft. My cheapie dial-gauge (which I don't fully trust) measures 0.12mm (5 thou) of radial movement. Seems to me that's a big old gap - and it certainly *feels* a lot - but MS's documentation suggests it's not wildly excessive. So what stops the oil seeping down that 5 thou gap and out into the clutch?
Edited by alpder, 04 April 2024 - 04:56 PM.
