Mk1 Flywheel Query
5 replies to this topic
#1 SuperDeLuxeNick
SuperDeLuxeNick
  • 602 posts
  • Local Club: Midweek Minis Portsmouth
Posted 11 April 2024 - 05:38 PM
Hello,
Engine nearly ready to go back in the car.
1963 Mini have the original gearbox refitted with a later 998 A+ engine.
The origianl engine was a 63 so had the very early 1 3/8" crank, rather than the 1.5" crank, so i have already swapped to the primary gear and its all gone together well with the clutch housing and good floats too.
I didnt think about the flywheel! I have the original pressure plate and spring type flywheel. However it of course is for 1 3/8" cranks not the 1.5".
Whats the best way forward? Ideally i would keep as much original stuff as possible - can i try and find a late 60s spring type flywheel? Or a lightweight option? Or am i better going to a diaphragm type?
Many thanks in advance!
#2 Spider
  • 13,939 posts
Posted 11 April 2024 - 07:19 PM
I'd suggest going to a later flywheel that takes the diaphragm spring. It'll save you loads of agony down the track and it's not something external that's seen.
#3 SuperDeLuxeNick
SuperDeLuxeNick
  • 602 posts
Posted 11 April 2024 - 07:38 PM
Yep seems to be the way forward.
Do i need another back plate or are they all the same/interchangeable?
#4 DeadSquare
DeadSquare
  • 2,768 posts
Posted 11 April 2024 - 10:36 PM
Shame that you have only just thought about the flywheel,as it really ought to be balanced with the crank.
#5 bpirie1000
bpirie1000
  • 2,122 posts
  • Local Club: Amoc
Posted 12 April 2024 - 06:12 AM
Also think about primary gears on the crank...
#6 Spider
  • 13,939 posts
Posted 12 April 2024 - 07:08 AM
It's been a long time for me here, but I think that'll interchange.
