Front Indicator
Posted 14 April 2024 - 11:58 AM
Posted 14 April 2024 - 03:17 PM
Sorry voltage to the TWO wires?
should only be voltage to one and the other to earth.
Posted 14 April 2024 - 08:00 PM
Posted 14 April 2024 - 08:10 PM
If you can get bulb to light with 12v positive to one side and a bridge to chassis on the other then you either don't actually have 12v to one side, the bulb has failed or you don't have a suitable earth point. Have you checked the bulb etc?
Edited by Davidmt, 14 April 2024 - 09:34 PM.
Posted 14 April 2024 - 08:32 PM
Posted 14 April 2024 - 08:45 PM
In the rear of light bulb holder (can’t think what that would be called?)
Or are you measuring the voltage at the loom behind the front grill?
I had to strip mine down and solder new wire.
Posted 14 April 2024 - 09:12 PM
assuming you have confirmed 12v right up to the back side of the lamp holder, and that lamp works fine when you swap it to the other side then the fault must be with the lamp holder, some sort of looseness in the bayonet fitting that stops the contacts touching correctly, etc
I'd order a new one, or you could try swapping the lamp holders left to right and see how that goes
Posted 15 April 2024 - 05:32 AM
Posted 15 April 2024 - 06:03 AM
Assuming the bulb is neither polarity directional or an LED then you either don't have 12v or a ground if other systems work and it's not the battery or ground leads. You also say some of the hazards aren't working so I would suggest you double check the wiring as suspect they are related and you don't have continuity within the offside indicator loom. If the nearside hazards are working then doesn't sound like the relay - seems more likely to be the wiring. What I can't understand is that you believe you have a 12v feed and a ground at the bulb - obviously you can't have if a good bulb does not work so you need to rethink that part and check the loom etc.
Posted 15 April 2024 - 08:00 AM
Sorry can you describe the process where you're wiring direct to the known good bulb
Are you using spare wire to connect directly from the back side of the lamp holder (where 12v was tested and confirmed) to the lamp for example and are you just holding that on temporarily by hand, or you used some sort of connector, or what (pics may help)
Just trying to get accurate info because something doesn't seem to add up
Am I reading it right the side and rear indicators on that side are flashing because obviously that eliminates a number of issues
Edited by stuart bowes, 15 April 2024 - 09:38 AM.
Posted 15 April 2024 - 09:54 AM
Posted 15 April 2024 - 11:05 AM
Posted 15 April 2024 - 11:10 AM
are these LED's or normal lamps
point to note the hazards are supplied separately to the indicators, that fault could be the hazard switch / relay (or the connections to the rear of the switch maybe)
when it's in the on position it supplies all the indicators from the hazard relay
when that's in the off position it sends voltage to the individual indicator circuitry via the indicator relay
Edited by stuart bowes, 15 April 2024 - 11:10 AM.
Posted 15 April 2024 - 11:54 AM
As above, you can have normal voltage, but very little current. If it's in bits hook up the 12v & try earthing it elsewhere. Also check you have the polarity the right way round, if the +ve is on the earth it might be going straight to earth via indicator mounting & bypassing the bulb.
The hazard fault can't be linked, unless there's a short that's taken out the fuse - which is shared with the interior light. Assuming it's a carb model.
