A friend has a used EN40B crank for sale. Are they overkill for a large bore road engine project.
I was wondering how i could go about checking it for wear and what the measurement tolerance would be before it was declared scrap?
Posted 16 April 2024 - 03:16 PM
Posted 16 April 2024 - 03:58 PM
The Turbo Metros didn't have EN40 cranks, so, Yes, for a road car, it is overkill, but nice to have the extra margin of strength.
You would need Cooper S or MG conrods.
The main bearings are 2" and the big ends are 1.625" easy to measure with a Vernier.
The Nitriding is not very thick, and if you grind them down .030", you risk going through the hardened surface layer. The workshop manual states a maximum of .020".
An EN40 crank it too good to be scrapped.
Posted 16 April 2024 - 04:13 PM
Posted 16 April 2024 - 06:52 PM
You also need custom thrusts if fitting an S crank in a Non-S block.
As Deadsquare mentioned, the Nitrididing is on very thin, even at a 0.010" you are through most of it. And after grinding, you'll most likely find it'll have a bend in it.
I find them brittle and out or all Mini cranks, these are the most prone to cracking.
Posted 16 April 2024 - 10:32 PM
For a road engine you really don't need more than a standard crank. However, the A+ cranks are better than the non A+.
