Gear Selection Problems
3 replies to this topic
#1 Finchman
Finchman
  • 21 posts
Posted 20 April 2024 - 04:57 PM
Took my 99mpi out this morning,clutch was biting at the very bottom,and gear selection was a problem.After 5 minutes drive I couldn't get it in any gear when the engine was running,as soon as I switched off the engine gear selection was smooth,no problem.Im thinking its a clutch issue because the gearbox was rebuilt 2000 miles ago Help!
#2 Lplus
Lplus
  • 996 posts
Posted 20 April 2024 - 05:18 PM
What was it like the previous time you took it out?  and how long ago?
#3 Finchman
Finchman
  • 21 posts
Posted 20 April 2024 - 05:33 PM
Took it for mot on 2nd of April....no issues
#4 Quinlan minor
Quinlan minor
  • 1,355 posts
Posted 20 April 2024 - 06:37 PM
Check the clutch fluid level and that there's no air in the system, first.
Check the deflection of the clutch release lever.
Check for fluid leaks from the slave and master cylinder.
Try pumping the clutch to see if that gets you anywhere.
My chief suspect would, probably, be the master cylinder, but eliminate everything else, first.
