Help A Fool With His Grease Gun
1 reply to this topic
#1 SteadyEddie
SteadyEddie
  • 26 posts
Posted 21 April 2024 - 05:47 PM
I've got a sealy 3 way fill side lever grease gun that I'm struggling to get going.
In the past I've run two cartridges through successfully, but on this new one I can't get it to pump anything through the hose. If I have no hose on there I can pump grease through freely, but the second I put a hose on (either a rigid or rubber one) I get no grease. I've tried all the tips I've seen online, back the cylinder off a turn, using the bleed valve, but no joy. Any help greatly appreciated!
#2 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 22 April 2024 - 09:48 AM
Do know if this will help, but I very recently had to get my grease gun going again after a few years of sitting idle.
The outlet pipe was blocked solid with dried grease which had the consistency of wax. I had to soak it in a bath of white spirit overnight and use a length of thin wire to unblock it.
Hope this helps!
Cheers, Steve.
