Carbs Running Out Of Fuel
32 replies to this topic
#1 Kevybmini
Kevybmini
  • 96 posts
Posted 23 April 2024 - 03:32 PM
Ok, here goes.
New engine build all running fine, head gasket goes so upgraded to stage 3. Since then soon as accelerate hard in say 2nd it’s as if the carbs run out of fuel. Vac gauge all over the place, 20 seconds later all is well and drive off again.
Done so far :
Cleaned out fuel tank and removed internal filter
Blew out petrol lines
4/5.5 PSI Facet (new) but had the same problem when using the mechanical pump, got 3 PSI at the carbs
Twin HS4’s
Checked and cleaned float bowls
Blew out the jets
Tried with and without fuel regulator
I’m at a loss what to try next
#2 viz139
viz139
  • 676 posts
  • Local Club: Irish Mini Owners Club
Posted 23 April 2024 - 03:50 PM
Sounds like a fuel volume rather than fuel pressure problem. Check that you haven't squashed the fuel pipe under the car. I had this problem only when driving hard.
#3 Kevybmini
Kevybmini
  • 96 posts
Posted 23 April 2024 - 03:53 PM
Mmmm that’s not a bad idea
#4 nicklouse
  • 18,657 posts
Posted 23 April 2024 - 04:33 PM
So if I read this right. You have greatly changed the engine spec and ability but not touched the needles?
#5 Kevybmini
Kevybmini
  • 96 posts
Posted 23 April 2024 - 05:00 PM
No haven’t touched the needles - currently has no6 needles and red springs. It seems to just run out of petrol when you rev out say 2nd gear - pull over just about running with vac gauge fluttering - 20 seconds comes back to life and off you go for another 1/4 mile
#6 Avtovaz
Avtovaz
  • 1,263 posts
Posted 23 April 2024 - 05:41 PM
try putting a new coil on it.
it could be something to do also with the advance? check the earth strap in the dizzy is ok if you still run a dizzy, and where the point go under the spring [the red or blue bit]  its on the right way, not earthing out on the body.
Edited by Avtovaz, 23 April 2024 - 05:44 PM.
#7 Kevybmini
Kevybmini
  • 96 posts
Posted 23 April 2024 - 06:00 PM
New Aldon electronic dizzy
#8 Lplus
Lplus
  • 911 posts
Posted 23 April 2024 - 06:34 PM
Upgraded to stage 3 from what?  cam change as well?
For twin HS4s I've found  blue springs and CP4 needles are a good compromise in lightly modded 1275.  Since you have no 6s in there, they must be fixed jet carbs, so the CP4s don't need modifying.
I'm asssuming a 1275...
#9 nicklouse
  • 18,657 posts
Posted 23 April 2024 - 06:35 PM
So have you checked the float chambers when it stops?
ie kill the engine when it “runs” out and then pop the covers off.
if you have not done that you don’t really know if it is running out of fuel or if there is another issue.
you will need to do this a few times to get a consistent result. Unless it is totally without fuel.
#10 Kevybmini
Kevybmini
  • 96 posts
Posted 23 April 2024 - 06:45 PM
Not a bad idea
#11 68+86auto
68+86auto
  • 974 posts
  • Local Club: Queensland Mini Car Club
Posted 24 April 2024 - 06:01 AM
Do you have a filter between the tank and pump? If so then remove it, unless it is a mesh screen type.
Edited by 68+86auto, 24 April 2024 - 06:01 AM.
#12 fatcatvera
fatcatvera
  • 17 posts
Posted 24 April 2024 - 11:20 AM
It is possible that the float valve is too small a diameter and is choking the flow into the fuel bowl. I'm aware if two tuned engines having this issue with HIF44 carbs fitted.
On both we fitted the 'Turbo' valve :- https://www.bullmoti...wzx1095/WZX1095
The diagnosis for each before the valve being changed was lambda going digitally high (engine going lean) and inspection of the float chamber showing empty of fuel.
If you're running an HS4 then I'm not sure whether larger diameter/bore valves are available or even whether this can be an issue on the HS4?
#13 Lplus
Lplus
  • 911 posts
Posted 24 April 2024 - 12:10 PM
The op has twin HS4s  I don't see how a pair of valves would be insufficient to fuel a 1275.
#14 Ethel
  • 26,022 posts
Posted 24 April 2024 - 10:48 PM
Float chamber vents?
Float pivots?
#15 Kevybmini
Kevybmini
  • 96 posts
Posted 26 April 2024 - 09:40 PM
Latest conclusion following much much messing about. The fuel pressure is too high so going to turn it down to 2psi. Was chasing not enough fuel but think it’s too much and flooding the engine. Update to follow when it stops raining this weekend. Thanks for all the replies
