Carbs Running Out Of Fuel
32 replies to this topic
#16 sonscar
sonscar
  • 3,031 posts
Posted 27 April 2024 - 08:18 AM
Would running out or too much fuel affect the vacuum gauge?The motor is just a pump?Steve..
#17 Ethel
  • 26,025 posts
Posted 27 April 2024 - 09:23 AM
The converse could be true - if it's recording an air leak that's bypassing the carb,
#18 Kevybmini
Kevybmini
  • 96 posts
Posted 27 April 2024 - 04:18 PM
I’m at a loss, lowered the fuel pressure and it still the same - runs fine for ages in the garage revving it ect. Drive 1/3 mile and it starts - vac gauge all over the place and have to pull over. 20 seconds then drive back home.
#19 Ethel
  • 26,025 posts
Posted 27 April 2024 - 04:43 PM
That sounds like a dashpot issue. Is  there oil in the damper tube? Damper damping? Spring springy? Communication ports  (holes by needle & through rear gasket face) communicating?
#20 Kevybmini
Kevybmini
  • 96 posts
Posted 27 April 2024 - 05:02 PM
Had the carbs stripped today and blew out the jets and checked everything. So odd
dash pots are fine - could anyone suggest why it’s only when the engine is under load. Thrash it in the garage with no issues
#21 Ethel
  • 26,025 posts
Posted 27 April 2024 - 09:31 PM
It will need to be under load to lift the piston. At idle the revs rise without needing much extra power so the throttle has less effect than piston.
#22 68+86auto
68+86auto
  • 974 posts
  • Local Club: Queensland Mini Car Club
Posted 27 April 2024 - 09:49 PM
Latest conclusion following much much messing about. The fuel pressure is too high so going to turn it down to 2psi. Was chasing not enough fuel but think it’s too much and flooding the engine. Update to follow when it stops raining this weekend. Thanks for all the replies
Get rid of the regulator and get the correct pump. Regulators cause issues. To reduce pressure they reduce flow.
#23 68+86auto
68+86auto
  • 974 posts
Check the ignition system.
#24 Kevybmini
Kevybmini
  • 96 posts
Posted 27 April 2024 - 10:31 PM
Might change the plugs again,
#25 Kevybmini
Kevybmini
  • 96 posts
Posted 27 April 2024 - 10:39 PM
It will need to be under load to lift the piston. At idle the revs rise without needing much extra power so the throttle has less effect than pistonah right - thanks
Ah right thanks
#26 cal844
cal844
  • 9,633 posts
  • Local Club: TFMOC
Posted 28 April 2024 - 12:50 PM
What coil do you have fitted?
#27 Kevybmini
Kevybmini
  • 96 posts
Posted 28 April 2024 - 03:21 PM
Aldon dizzy and 3 ohm flame thrower
#28 Kevybmini
Kevybmini
  • 96 posts
No 1 spark plug is very white if that makes any sense. No 2 normal
#29 Cooperman
  • 23,315 posts
Posted 28 April 2024 - 07:16 PM
With my twin H4 carbs on my 'S' I run at 3.5 psi from my twin Facit pumps.
#30 imack
imack
  • 2,176 posts
Posted 28 April 2024 - 07:31 PM
Possibly running excessively lean at full throttle, causing the exhaust valves to overheat and bind in the guides, preventing them closing and engine dies. Lack of compression so won't restart. Valves cool sufficiently after 20-30 seconds and free off adequately in guides allowing them to close again. This would account for vacuum gauge readings too.
If the above should be the cause, the valves and guides will need replacing and the cam and followers will likely be wrecked as well.
Have you had it set up on a rolling road since modifications have been carried out?
