Misfire/stumble/flat Spot Between 3-4Krpm
33 replies to this topic
#31 brivinci
brivinci
  • 1,225 posts
Posted 28 April 2025 - 05:28 PM
UPDATE: I am not 100% sure how for why, by this flat spot/missfire has now been corrected. Could be one thing, or a series of little things. I hate not knowing but I will list out what I did, and what I found. Not one thing "fixed" this straight away. Durning a 500 mile trip, we noticed it was improving...
Motor was out to replace ring gear on flywheel. Flywheel, crank, Cooper S pulley were all balanced (confirmed balanced)
Cam timing was set to Calver ST's specific degree.
Distributor was installed and clocked correctly.
Rotor replaced: The one in there had a burn spot just off the edge of the metal piece. This piece also wiggled around. Junk
Found my new fuel trap was leaking from seam. Glued/siliconed to get me on the road. Replaced with original Rover unit I had once home. (2nd replacement trap to fail)
Noticed throttle body bolts were not as tight as I would have thought. Removed sandwich plate, replaced gaskets and refit with blue loc-tite.
Reset roller rockers and gapped plugs.
Any one of the above, if wrong/loose/worn/leaking could have caused from issues. Not sure which is was (or if its something else entirely) that got rid of the issue. I have a feeling it will come back, with my luck. Fingers crossed and thanks for coming along for the ride!
#32 ultimax5
ultimax5
  • 23 posts
Posted 02 May 2025 - 03:50 AM
Hi brivinci, glad to know your car is running well now.  Just curious, did you end up changing your fuel pump?
#33 brivinci
brivinci
  • 1,225 posts
Posted 02 May 2025 - 05:57 PM
I never did end up changing it. I have had so many issues with new parts failing that I will hold off (for once) just replacing things "just in case".
I have put a few more miles on the car and the problem still seems sorted. Very excited to have this ripping for a fresh season. About to sign up for an AutoX event. What are these called in the UK? Where you race around cones against the clock?
#34 ultimax5
ultimax5
  • 23 posts
Posted 03 May 2025 - 05:56 AM
I see, thanks for your reply and really good to know your Mini is still behaving itself.  I think it's called the same thing, Autocross.  I live in Malaysia though.
