driving to work today in my mini van that has a1275 mg metro engine in it started to run poorly but it was only 10 minutes into driving her so figured she was sill a bit cold but then the engine cut out and wouldn't turn over like the battery was disconnected still had electrical power however after 10/15 minutes she came back to life and started again any ideas?
Metro Engine Cut Out
Posted 30 April 2024 - 08:08 AM
Posted 30 April 2024 - 10:00 AM
i put new plugs in and ht leads a few months back
Posted 30 April 2024 - 10:53 AM
Maybe fuel system venting, carb or tank breather, or something in the ignition overheating. If it has the anti run-on valve still it might be that.
Posted 30 April 2024 - 11:47 AM
where does the tank breather pipe fit to the van
Edited by 1995spi, 30 April 2024 - 11:47 AM.
Posted 30 April 2024 - 01:57 PM
It doesn't. You have to use a vented cap.
Not sure how that would stop the engine from turning over though...
Edited by Lplus, 30 April 2024 - 02:03 PM.
Posted 30 April 2024 - 02:59 PM
Posted 30 April 2024 - 03:13 PM
Posted 30 April 2024 - 03:37 PM
Also be aware that batteries can have internal faults too.
Posted 30 April 2024 - 05:05 PM
Posted 30 April 2024 - 09:57 PM
My bad, as the cool kids say.
I got fixated on the Metty bit, I guess.
Poor battery connections shouldn't matter too much once it's started & the alternator is doing its stuff. The ignition switch maybe? S'pose you might have some extra tinkering too, if it's a pre engaged starter in an inertia equipped van - earth screws if your using a body mounted solenoid as a starter relay? Though that should affect a running engine either.
Posted 01 May 2024 - 06:27 AM
Good luck
Posted 01 May 2024 - 01:53 PM
i think the ignition cable came loose that's why it wouldn't crank
Posted 02 May 2024 - 08:10 AM
