Oil Seal And Pre Verto Spring Clutch Replacement
Best Answer BrianHJ , 26 June 2024 - 07:18 PM
Finally completed and working well.  I did fit 1mm washers between the pressure plate and the straps to stop the crunching in first and reverse gears. I couldn't have completed this without the help from everyone replying in the forum with hints/tips and offers of parts.  Thank you all, Brian
Go to the full post
20 replies to this topic
#16 Spider
  • 15,878 posts
Posted 27 May 2024 - 09:36 PM
I'd suggest here removing the thrust bearing and adding a washer between the bearing and plunger to pack the bearing out closer to the flywheel. Given your description here, I'd say / guesstimate something around 0.8 to 1.0 mm thick will do it. If you want a more accurate measurement for the spacer thickness, before taking anything apart, measure the free play on the plunger.
Which actually brings up another thing that would be wise to do here. Unless your plunger has already been changed (it should have been done at a service point by the dealer), fit the later plunger and over-throw nuts, adjust these last as per the workshop manual.
#17 BrianHJ
BrianHJ
  • 20 posts
Posted 28 May 2024 - 03:09 AM
Thank you, I will give that suggestion a try . I did fit a new bearing and plunger, I will just have to find a big enough washer to fit it.
#18 BrianHJ
BrianHJ
  • 20 posts
Posted 29 May 2024 - 06:18 PM
I had to fit a 2.3mm washer to take up the play, which worked; however it crunches slightly getting into first or reverse gear now.  When torqued up how close should the diaphragm be to the flywheel, it seems very depressed and close. I thought about fitting a washer to each tab to allow more room for movement in the diaphragm to give more clearance when depressed.  My only worry is slippage on driving.
#19 GraemeC
GraemeC
  • 7,476 posts
Posted 30 May 2024 - 08:50 AM
The bevelled spring on the inside of the diaphragm should be pretty much flat when torqued up.
If it is a new clutch plate then having the spring so its not quite flattened out gives the best compromise between initial clutch grip and long service life
#20 BrianHJ
BrianHJ
  • 20 posts
Posted 31 May 2024 - 06:23 AM
Thank you, it does get into gear and it drives well in the other gears, I was concerned that it was going to cause a problem as it sits only a few millimeters from the flywheel.  Thanks for the info
#21 BrianHJ
BrianHJ
  • 20 posts
Posted 26 June 2024 - 07:18 PM   Best Answer
