Bell Housing Question
Best Answer postve , 13 May 2024 - 04:31 PM
OMG - I just noticed - lolololol - okay big time rookie lack of knowledge- it’s buried in there lololololol - thx guys for bearing with me as I learn but well worth it for
Me and another pic
Now to figure out how to remove it
https://ibb.co/SrcBcY0 Go to the full post
25 replies to this topic
#1 postve
postve
  • 588 posts
Posted 10 May 2024 - 12:10 PM
Hey guys, so doing a dry fit of the Bell housing and find it gapped as if the main shaft needs to be recessed more to allow it to seal - same one that was on before and puzzled? Here’s some pics and hoping just my lack of knowledge
https://ibb.co/RpH5byh
https://ibb.co/cJbrpHL
https://ibb.co/QnRLSfD
https://ibb.co/61PtNyS
#2 postve
postve
  • 588 posts
Posted 10 May 2024 - 12:13 PM
Another view
https://ibb.co/gRYnxGs
#3 KTS
KTS
  • 2,490 posts
Posted 10 May 2024 - 01:41 PM
the transfer housing can get hung up on the idler gear (..it's not the mainshaft) and/or first motion shaft bearings - turning the idler gear whilst assembling can help
alternately, try fitting the casing without the idler gear in place to see if the problem is elsewhere
#4 Designer
Designer
  • 757 posts
  • Local Club: LSMOC
Posted 10 May 2024 - 03:06 PM
Hi,
I had the same problem and thought I had done something wrong. Went away and scratched my head a few times and could not come up with any answers.
Went back and had another look to see what the problem could be. Slide it off and then slide it back on with a bit of a jiggle and wiggle and it went on all the way.
What stopped it going on all the way first time I have no idea.
It happened the next time I had the engine out so jiggled and wiggled and fully fitted.
Paddy
#5 postve
postve
  • 588 posts
Posted 10 May 2024 - 03:19 PM
Hi,
Paddy
thx Paddy let me take a look sounds like a plan
#6 GraemeC
GraemeC
  • 7,472 posts
Posted 10 May 2024 - 04:59 PM
I’d say that’s the 1st motion shaft pilot bearing not sitting into its outer race nicely.
I’d be tempted to put plenty of grease on the bearing rollers and try and get them to ‘stick’ into their cage.
The other possibility is if the alignment dowels are a bit chewed up or need cleaning up
#7 Spider
  • 15,817 posts
Posted 10 May 2024 - 05:13 PM
As Graeme has suggested, I too can see it's the First Motion Shaft Outrigger Bearing.
If it's a genuine item (and it looks like it), the outer shell that's in the Flywheel Housing has a small tapered lead in. As it's used, the rollers of the bearing are falling away a wee bit and catching on the bearing shell. Usually if you spin the Idler Gear as you ease the housing on, the rollers will 'ramp in' in that small taper that's on the outer shell allowing it all to slip together.
Don't force it or you'll end up needing to replace the bearing after you break the cage.
#8 postve
postve
  • 588 posts
Posted 11 May 2024 - 01:42 PM
This is the one I bought guys and still tricky will have to think this through as it all lines up, measured depth in clutch housing - ok - compared 1st motion shaft pilot- ok - removed idler gear , still gets hung up on the roller, greased it all up too - will keep at it
https://ibb.co/2qy8xm6
#9 Spider
  • 15,817 posts
Posted 11 May 2024 - 06:42 PM
Is the Flywheel Housing the same one that came off this Gearbox ?
The Outrigger Bearing is in 2 parts. The one part has the Rollers on it and is attached to the shaft with the circlip. The other part is just a steel Ring that's in the Flywheel Housing. Be aware - these are matched parts, you usually can't take one part from one set and expect it to fit the other part from another set.
#10 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 May 2024 - 11:11 PM
In the 4th pic, even when they are brand new these days, those rollers don't always sit nicely in the brass cage.
Your problem is not unusual.  This is where an 'engine stand' becomes really useful, as I always swing the engine with the tail of the crank pointing straight up in the air so that gravity isn't trying to drop a roller out of the cage.
The transfer housing usually slips easily on, but I sometimes have to rotate the Diva gear a couple of turns back and forth to get the rollers into the race.
#11 postve
postve
  • 588 posts
Posted 12 May 2024 - 01:17 AM
You may have just solved my problem as will check tomorrow as Ithink I swapped the rings (grabbed the old rather than new) - let me check tomorrow as I keep everything until I am done old and new parts just for times like this where I make mistakes.
#12 Shooter63
Shooter63
  • 1,278 posts
Posted 12 May 2024 - 09:50 AM
Personal view here but I would dress the dowel which has the burrs on it, then I normally stick the roller bearings in with Vaselene which is a petroleum jelly, and as others have said, it's a lot easier to do with the engine on its end.
Shooter
#13 postve
postve
  • 588 posts
Posted 12 May 2024 - 02:11 PM
Spider - the steel ring barely sits in the flywheel housing - let me grab a picture
#14 postve
postve
  • 588 posts
Posted 12 May 2024 - 02:16 PM
Shooter
Good point and note - engine is out for a rebuild - and what I have has to suffice for now as just a dry fitting. Dowels I can simply replace for now
Edited by postve, 12 May 2024 - 02:24 PM.
#15 postve
postve
  • 588 posts
Posted 12 May 2024 - 04:27 PM
https://ibb.co/xFDstVR
