Dizzy For 1275
Posted 22 May 2024 - 07:48 AM
we are putting to cab on the 1275 , I need to change the dizzy as I plan to use the old loom that’s in the car, would an Aldon one work?
I’m looking to rebore the engine out in time and do other mods, but would one of these work on the standard engine to start with?
Also vac or non vac?
Thanks Dean
Posted 22 May 2024 - 12:51 PM
You can use the 65dm4 electronic dizzy with an appropriate coil. Think it was the standard dizzy for '90's 1275 carb engines. If there are engine mods done to the 1275 then have the dizzy recurved by AC Dodd.
Edited by whistler, 22 May 2024 - 12:51 PM.
Posted 22 May 2024 - 01:42 PM
also bear in mind there is no temp. sensor take off port on the head, spi is from inlet manifold so will need to sort that
Edited by coopertaz, 22 May 2024 - 01:43 PM.
Posted 22 May 2024 - 02:19 PM
You can buy thermostat sandwich plate with temp. sensor takeoff.
Posted 22 May 2024 - 02:42 PM
I have brought a 1275 spi engine to fit in my mini,swapping out the a series 998 engine.
Thanks Dean
Can't tell if the loom is right without knowing the age of the car, and aftermarket distributors will almost certainly need wiring mods anyway.
Posted 22 May 2024 - 07:18 PM
Given that you want something to get going with and likely modify the engine down the track, this will be fine;-
http://www.minispare...ic/ADU3825.aspx
I've bought and fitted many of these distributors from the Mini Spares range and found them quite good.
Posted 23 May 2024 - 09:27 AM
Posted 03 June 2024 - 08:33 AM
was just pointing it out so they have all bits to do job at the same time
Posted 03 June 2024 - 09:00 AM
The hole can be drilled and tapped and then an adaptor with the correct seat installed. The head will also need the heater take off drilled.
