Hi,
I still have a problem with my 1998 MPI. It draws around 170ma from the battery and after a few days (1-2 weeks) the battery is empty. I checked all the fuses and the c4 fuse draws 80ma. It is for the radio, horn relay and?? I disconnected the radio and still 80ma. So the radio is fine. I took all the yellow relays out of the engine bay - still the same. Where is the horn relay?? Is it in the car behind the dash?
70ma are drawn by fuse number b6 which is responsible for the alarm and so on. This might be normal??
Thank you very much
Thomas
