Painting My Subframes
5 replies to this topic
#1 Ruth's Mini
Ruth's Mini
  • 104 posts
Posted 07 June 2024 - 09:53 PM
Can anyone tell me the correct black to use on the subframes?
Did the factory paint them gloss black or was it a semi-gloss?
thanks in advance
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 07 June 2024 - 11:26 PM
Paint the front one white.  When you drop anything in the engine compartment, it makes it so much easier to see things.
For the same reason, I paint the rear subframe a sandy mud colour.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 08 June 2024 - 12:36 AM
thanks in advance
Are you going to use the car in concours events?? if not a Gloss Black will do the job nicely.
However its entirely up to you. Just to add some info, i converted an new old stock OE Wet rear subfame to dry for my Clubby and the paint on that was not gloss so maybe a semi gloss. Bear in mind though it was old and not stored in the best of conditions. Its now powder coated dark blue along with the front subframe.
#4 Bobbins
Bobbins
  • 1,526 posts
Posted 08 June 2024 - 04:46 AM
I believe the original black was closer to a gloss than a satin/semi-gloss, although unless you’re dead set on painting it yourself I’d have it powder coated.
The powder coater I use will blast the subframe, zinc coat followed by black for £75, I consider that to be decent value for the time I’d need to spend on it.
#5 weef
weef
  • 557 posts
Posted 08 June 2024 - 10:59 AM
I think it will be quite difficult to replicate the factory finnish, it must have been quite an art to put so little paint onto a surface and still manage to give it a semi gloss sheen.
#6 Designer
Designer
  • 760 posts
  • Local Club: LSMOC
Posted 08 June 2024 - 06:53 PM
The semi gloss was probably due to the rust starting to come through.
