1330Cc Hif44 Help Please
24 replies to this topic
#1 Steve66
Steve66
  • 67 posts
Posted 18 June 2024 - 11:56 AM
Hi
I have just finished rebuilding my 1330 engine with following spec and it coughs bad around 2000rpm. I have rebuilt the carb and float etc all set up to the manual.  It is possible to drive through it if you put your foot down but as it’s a brand new engine want to run in
I have tried everything I can think of so any ideas greatfully received
1330cc
mg head, unleaded new valves etc
Minispares evolution 001 cam (similar to mg cam I am told)
Minispares evolution electronic distributor
standard new rockers
timing 8deg
compression about 10:1
running on super unleaded
HIF 44 with BDL needle
Minispares cone filter
Don’t know make of exhaust but is centre exit about 2” diameter twin box steel
tickover is quite lumpy and runs on
thanks
Steve
Edited by Steve66, 18 June 2024 - 01:03 PM.
#2 Ethel
  • 26,073 posts
Posted 18 June 2024 - 12:20 PM
Too much static advance?
If it's running on, without really warming up, it must be close to detonation.
#3 corrado vr6
corrado vr6
  • 678 posts
Posted 18 June 2024 - 12:39 PM
I too have similar but slightly opposite to you, mine bogs down in the lower rpms and then comes alive at 2000rpm.
Have you checked the dash pot oil and what oil did you put in?
#4 Steve66
Steve66
  • 67 posts
Posted 18 June 2024 - 12:54 PM
Hi dash pot oil is 20/50 which I have used for years with no problems
thanks for the suggestion though
I have a feeling it’s the needle but no idea which way to go
#5 Steve66
Steve66
  • 67 posts
Posted 18 June 2024 - 12:57 PM
Hi it only runs on when hot
strangely it needs choke for cold start and then is instantly too rich with choke and only runs without choke
#6 Ethel
  • 26,073 posts
Posted 18 June 2024 - 02:00 PM
How quickly does it get hot though.
With any needle you ought to be able to get some improvement in a specific spot. In a stooped ******* is right twice a day way.
The hif choke is separate, so has more effect the nearer you are to closed throttle. Sounds unlikely to your problem though.
#7 Steve66
Steve66
  • 67 posts
Posted 18 June 2024 - 02:29 PM
It gets hot fairly quickly.  The engine is still tight though.  Only 50miles so far
#8 Steve66
Steve66
  • 67 posts
Posted 18 June 2024 - 02:30 PM
What would be the best needle?
 I have just done a plug chop after a run and plugs are a bit on the rich side
#9 lippo
lippo
  • 144 posts
Posted 18 June 2024 - 07:08 PM
 The BDL needle is the standard MG Metro needle. I 'think' my 1275 is an MG Metro engine, and has a BDL needle in the HIF44. It ran super rich when I bought it. I've backed it off 1 1/2 turns and it still runs rich. BER is a leaner needle, but it's difficult to tell what you need unless you can find out what your emissions are (mine was 8% at MOT, so way over 4.5% limit).
 Have you tried moving the dizzy clockwise/anti clockwise to see if the car runs better? The timing may be the issue. I'm certainly no expert though.
#10 lsto
lsto
  • 606 posts
Posted 18 June 2024 - 07:12 PM
Call AC Dodd or someone similar to set it up and tune it. If you have spent a fortune on it then spend a little more and get it set up correctly, no point in all that money if your not getting the best out of it. Plus if the fuelling is out you could wash out your engine.
#11 lsto
lsto
  • 606 posts
https://youtu.be/oir...7OFZsf72l_-rBuI
Funny enough @ACDodd has just done a vid on borewash.
Edited by lsto, 18 June 2024 - 07:22 PM.
#12 croc7
croc7
  • 817 posts
Posted 19 June 2024 - 01:33 AM
Try this website; Su Midel Haystack   a terrific tool to help with needle selection
#13 KTS
KTS
  • 2,461 posts
Posted 19 June 2024 - 09:46 AM
https://sucarb.co.uk/needle-comparison
as mentioned above, until the rings have bedded in properly you should be aiming to run with the mixture on the lean side to avoid bore wash
#14 corrado vr6
corrado vr6
  • 678 posts
Posted 19 June 2024 - 10:10 AM
How new/clean is your fuel tank?
Do you have any inline fuel filters before the carb?
I have two filters before the carb and yet the gunk had still found its way into the float bowl. I’m hoping this is my issue 🙏🤞🏻
I have just removed my tank due to the gunk and rust.
https://www.dropbox....d8623cveyt&dl=0
https://www.dropbox....rthdh4pnjg&dl=0
https://www.dropbox....nzb5l4zyte&dl=0
#15 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 19 June 2024 - 12:49 PM
What plugs are you using?
