I've recently installed my HIF44 and begun the tuning process
The first step is always to check the ignition system is working properly:
What plugs are you using and what gap? Are the plugs black from being rich?
What coil are you using?
You've set the base timing to 8 degrees, have you checked the timing at 2000, 3000, 4000, 5000 rpm?
Do you have vacuum advance? Is it working and how much advance is it giving?
Once the ignition system is sorted you can move onto the carb. Once the engine is hot at operating temp:
Set the idle mixture using the screw
Check the mixture at 2000, 3000, 4000, 5000 rpm and note this down.
Leave the engine to idle for a few minutes and make sure the mixture is stable, isn't varying up and down too much or trending higher or lower over time
Bring the engine back to idle and then snap open the throttle and check the mixture. If you have the right damper and oil it should get richer when you snap the throttle.
Getting the right settings, especially when running in are critical for the life of the engine
