mot
Posted 20 November 2006 - 04:58 PM
before i get too carried away as im putting my clubman on the road with original engine it will be ready for mot in the next couple of months there are a few issues i would like ironed out ive tried a search but no answer to these,
do i have to have a full interior or will a drivers seat and belt surfice.
do the arches have to cover the whole tyre width or can it set out up to an inch
it wont be sprayed at this time so will be tstty paintwork does this matter.
i have a 1977 car but have no reverse lights do i have to fit some
i think thats about all very minor i know but any help would be gratefully received
lee
Posted 20 November 2006 - 05:17 PM
From what I can make out you don't need a reversing light (nor a fog light as it's pre 1980). I guess if you only have one seat then you only need one belt, too.
do i have to have a full interior or will a drivers seat and belt surfice?
drivers seat and belt is fine.
do the arches have to cover the whole tyre width or can it set out up to an inch?
As long as all the TREAD is covered by the arch and not visible from above then you're ok, but the tyre wall can protrude.
it wont be sprayed at this time so will be tatty paintwork does this matter?
no this doesn't matter at all. Paint condition isn't an MOT requirement. Rust is.
i have a 1977 car but have no reverse lights do i have to fit some?
Reversing lights are not an MOT requirement.
Edited by Retro_10s, 20 November 2006 - 05:18 PM.
Posted 20 November 2006 - 05:18 PM
I dont see why not, but you must only have the drivers seat in (and it must be securely mounted and the belt must work as intended !)
I believe that you arent allowed to have any of the 'tread' showing out of the archline when looking down from above. I know a couple of people that have it sticking out a little though and they passed.
No probs as long as the bodywork is sound and all the panels are there !
With regards to the light, I am not 100% sure but if there isnt one fitted as standard, I dont think you have to have one. There might be a cut off point for this age wise though
Posted 20 November 2006 - 05:20 PM
Posted 20 November 2006 - 05:26 PM
At least our answers are pretty much the same !
Posted 20 November 2006 - 05:56 PM
Posted 20 November 2006 - 06:06 PM
Regarding the arches, IIRC I don't think it's an MOT requirement that they don't protrude, but it *is* a legal one. So theoretically they might pass it and you could get nicked on the way home from the test station!
Correct, as for the others... answers above
And just before you ask, no you don't need a fog light either, but if it's fitted, it MUST work ( with a tell tale switch )
As for the colour, when my '72 when for it's first MOT they had to inquire as to what colour it was, as the bonnet was red and green, the main panels were Yellow and blue, the doors were brown and the boot lid was purple ! and the rest of it was filler and primer... lol
Edited by GuessWorks, 20 November 2006 - 06:11 PM.
Posted 20 November 2006 - 07:26 PM
lee
Posted 20 November 2006 - 07:33 PM
Posted 20 November 2006 - 07:41 PM
Posted 20 November 2006 - 08:05 PM
Interesting point on passenger seat though, might as well stick it in there to be on the safe side.
Posted 20 November 2006 - 09:02 PM
If you remove the passenger seat, make sure that you do not have the rear seat cushion in. If you do this then becomes the 'front nearside seat',(as the one next to the driver is missing) and will then require a seat belt even tho' your 77 car is not fitted with rear seat belts. So to recap, make sure all you have in is the drivers seat no other 'cushions/squabs'
