Mpi Front Wheel Play On Mot
Best Answer wilsonch , 03 July 2024 - 02:14 PM
Thanks for all the advice
I will start checking through the list paying more attention to the steering.
Alright, sorted. sometimes you have to hold your hands up and take all the blame for being stupid.........just me then.
taking Spiders advice started looking more closely at the steering.
Found the steering arms that bolt to the hubs loose, but only a fraction.
The reason i didnt even contemplate this is i have built up the hubs well before fitting, thought i had tightened the bolts sufficiently and even bent the lock tabs over.  one of those " thats done i can put that to one side and do something else now"
I can only think that having driven it a few miles its somehow settled a little, enough to give me a headache.
Thank you all for the pointers and advice. as this is my first mini rebuild,  its all a bit of a learning curve.
Much appreciated
Chris
Go to the full post
22 replies to this topic
#1 wilsonch
wilsonch
  • 120 posts
Posted 30 June 2024 - 03:43 PM
Afternoon
     Just had my first MOT after a full nut and bolt rebuild.
on the 'wheel wobble' test there appeared to be play in the wheel bearings.  only however when shaking the wheel with hands at 3 & 9 oclock.  hands at 12 & 6- no play.
I assumed the hub nut would need a tighten even though i did them to the correct torque?
when i have tried this they wont tighten any more.
I have new timkin bearings in the hubs.
i did not replace the CV joint.
I have read this https://www.theminif...wheel-bearings/
its a great guide but no shaft measurement?
What is the diameter of a new CV joint shaft. i cant help thinking that they are worn
My very basic measuring puts the shaft at 31.7mm
measuring the bearings (with a vernier not a micrometer) they are 32mm.
Is this where Iam falling flat?
any help greatly appreciated, feeling a little deflated....i thought i had finished and i am taking the front end to bits again.
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,405 posts
  • Local Club: Amoc
Posted 30 June 2024 - 04:20 PM
What did the mot person say about it?
I trust wheel nuts were re torqued after a few miles and the slack is not there...
How much grease did you put in the bearing?
#3 imack
imack
  • 2,216 posts
Posted 30 June 2024 - 05:20 PM
Surely play in a wheel bearing will show up when rocking the wheel in all directions, not just at 3&9 o'clock. Presuming the track rod end and rack are OK, I'd be making sure the steering arm is tight on the hub. This will give free play in the3&9 o'clock position.
#4 andyapanel
andyapanel
  • 627 posts
Posted 30 June 2024 - 07:04 PM
You may not have done anything wrong.
Apparently there is more acceptable play in a mini than a more modern cars because it is an old design.
However, younger mechanics brought up on Japanese and German engineering may feel play as untoward wear.
The trick is to find an MOT station that knows what is acceptable and what is dangerous.
Currently I use a Landrover garage; the old guy at the VW place who would MOT my cars retired.
Good luck
#5 imack
imack
  • 2,216 posts
Posted 30 June 2024 - 07:36 PM
Good luck
Some designs of steering and suspension do have more free play than a modern car, but a Minis steering and suspension design isn't one of them. Classic mini steering, suspension and wheel bearings won't have any noticeable free play at any ball joint, bush or bearing when in good condition. Infant, they probably have less movement than most modern vehicles as they don't have the 'compliance' bushes as fitted to the majority of modern cars.
#6 sonscar
sonscar
  • 3,070 posts
Posted 30 June 2024 - 08:08 PM
Try the rocking with the brakes hard on.This should stop movement due to wheel bearings.Carefully check ball joints.Agree the mini should not have play by design.Steve..
#7 Midas Mk1
Midas Mk1
  • 5,794 posts
  • Local Club: S.U.N.M.C
Posted 30 June 2024 - 08:11 PM
Good luck
No, play is play, regardless
I work on relatively high end cars, play is play and most have some by 3 years and require replacement control bushes..
Same for any car, classics should just be as tight.
Edited by Midas Mk1, 01 July 2024 - 02:08 AM.
#8 Spider
  • 15,212 posts
Posted 30 June 2024 - 09:30 PM
I agree with imack - doesn't sound like wheel bearings to me.
Steering related I'd say - check the rack, that it's tight in the body, the rod end and that the arm is tight on the hub.
#9 wilsonch
wilsonch
  • 120 posts
Posted 01 July 2024 - 07:14 AM
Many thanks for all the advice.
The major wear plates are new
Teack Rod ends, ball joints, hub bearings, all rubbers on the arms, tie rods.
Not new, steering rack, hubs, cv joints.
But for a little context the car only has 15k miles on it, it sat for 4 years on a drive then 4 tear rebuild.
I'll try rebuilding and have another look, try with the brakes applied.
I did think that the hub nut could be bottoming out I'll try adding another washer.
Im clutching at straws but will try anything at the moment.
#10 sonscar
sonscar
  • 3,070 posts
Posted 01 July 2024 - 10:36 AM
Do not guess,get assistance to locate the actual fault.You may spend hours and £££ and still have a problem if you don't.Steve..
#11 wilsonch
wilsonch
  • 120 posts
Posted 01 July 2024 - 06:02 PM
I am having another look at this.
I have measured between the face of the bearing and the start of the splines.
I am just pushing the hub onto the CV shaft here.
53828400211_04ce63ce21_c.jpgfront hub by Christopher Wilson, on Flickr
And also measured the disc where the splines have been 'smoothed' off.
53828636283_c59ffa41b3_c.jpgfront hub 2 by Christopher Wilson, on Flickr
this is less than the measurement above, these are new discs from mini spares, so tightening the hub nut will never force the disc into the bearings enough to clamp tight.
However i do appear to have made a small school boy error. looking at the haynes manual, I do not have fitted, the oil seal spacers that fit between the bearing and the inner oil seal.
My question about the spacer is. is this spacer only resting on the outer part of the bearing or does this spacer rest across the whole face of the inner bearing, like a big washer, this will give an extra 5mm or so.
Chris
Edited by wilsonch, 01 July 2024 - 06:33 PM.
#12 sonscar
sonscar
  • 3,070 posts
Posted 01 July 2024 - 07:01 PM
Are you measuring correctly?From the bearing to the start of the groove and not the start of the splines on the hub is what you need.Apologies if this is what you mean.the spacer behind the bearing at the back plays no part.Steve..
#13 wilsonch
wilsonch
  • 120 posts
Posted 01 July 2024 - 07:37 PM
I have just taken the o/s apart and with just me pushing the cv forward and having pushed the bearing back there is 7mm between the face of the bearing and the start of the groove. Measuring the smoothed spline it's 7.5mm.
I am sure when there is more compression on the bearing that 7mm will increase so in effect the spline is hitting the cv shaft..... If that makes sense.
#14 wilsonch
wilsonch
  • 120 posts
Posted 02 July 2024 - 04:24 PM
53829612237_ba068c1dae_c.jpghaynes hub fitting by Christopher Wilson, on Flickr
I hope this is clear.
paragraph 12 says insert drive shaft but do not fit split collar yet but first insert plain washer to the dimensions in fig 3.12.......is this correct? any one else do this ?
in the haynes manual fig 4.3 on page 10.4 does not show this extra washer.
chris
Edited by wilsonch, 02 July 2024 - 04:27 PM.
#15 wilsonch
wilsonch
  • 120 posts
Posted 02 July 2024 - 05:35 PM
heres the car itself.
53831021359_6d2172070e_c.jpgmini complete by Christopher Wilson, on Flickr
