Electronic Distributor
18 replies to this topic
#1 Robbie224
Robbie224
  • 28 posts
Posted 08 July 2024 - 09:54 AM
Hello. Does anyone know best electronic distributor would be best for a 71 Austin 1300gt ? Would like to go fully electronic with built in vuccum advance. Suggestions appreciated.
#2 PeterG
PeterG
  • 34 posts
Posted 08 July 2024 - 11:49 AM
123. I fitted one on my 1380 carb. Easy to set up. Works perfectly. Choice of preset timing curves. You can get negative earth or positive earth for A series.
https://123ignition.com/
#3 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 08 July 2024 - 11:57 AM
https://minispares.c...MS.aspx|Back to
Or an A C Dodd re-curved powerspark unit
#4 Robbie224
Robbie224
  • 28 posts
Posted 08 July 2024 - 06:24 PM
Does ac Dodd curve distributors for power spark dizzy?
#5 StefanMini
StefanMini
  • 85 posts
  • Local Club: M.S.C.N
Posted 08 July 2024 - 06:36 PM
123 ignition, I have it now a couple of years on my Mini with 1293 stage 3 engine and happy with it.
Also I hear that the recurved ones from AC Dodd are really good.
#6 Spider
  • 14,899 posts
Posted 08 July 2024 - 06:48 PM
I've fitted quite a few of the Distributors that Mini Spares offer. As a matter of course, I have tested every one before fitting and found their curves spot on. I feel they represent excellent value for money and are available in both points and electronic types.
I run CSI in a couple of the cars for over 12 years now. These have literally been through hell and high water. I have found these to be brilliant and the curves in them well suited to the A series engine. Caps and Rotors are commonly available Lucas types so easy to come by.
https://minispares.c...|Back to search
#7 PACINO
PACINO
  • 752 posts
Posted 08 July 2024 - 10:04 PM
..để hút nó
Edited by PACINO, 09 July 2024 - 05:54 PM.
#8 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 09 July 2024 - 12:31 PM
Another vote for AC Dodd recurved distributor.
Personally I'd suggest getting AC to come and optimise the fuelling of your engine too. Very very worth while.
But a few basic checks are plug gaps, plug lead resistance and coil Resistance.
Edited by cal844, 09 July 2024 - 12:35 PM.
#9 Robbie224
Robbie224
  • 28 posts
Posted 10 July 2024 - 09:55 PM
Thanks for all the replies. It's a twin hs2 ac Dodd needs a afr gauge fitted which I haven't got. Dizzy fitted at moment is a 25d with ported vuccum with accuspark electric fitted plugs set at 35. I do like the the twist tune d23 none vuccum. Engine has the 11 stud 940 large valve head. Would swifttune csi 23d work OK?
#10 timmy850
timmy850
  • 3,340 posts
  • Local Club: MITG
Posted 11 July 2024 - 01:59 AM
Unless you have a high power ignition system & 0.8 ohm coil your plug gaps will be too big. Most minis should have 25 thou gaps
What's wrong with your current setup and why do you want to change?
#11 Robbie224
Robbie224
  • 28 posts
Posted 11 July 2024 - 11:58 AM
It is a higher spark module by accuspark. Car does runs well
But 25D original distributor is old not knowing if it has the best advantage curve. Swifttune csi might bring out performance that could be missing. It is a gamble I agree .
#12 timmy850
timmy850
  • 3,340 posts
  • Local Club: MITG
Posted 11 July 2024 - 12:09 PM
Get a proper timing light and measure your current advance curve & check the vacuum advance is functional. That’s the only way to know what your distributor is doing now. If it has a decent curve & minimal scatter you won’t see much if any improvement with a new distributor
What coil do you have at the moment? How many ohms is it rated at?
Which Accuspark kit did you get? I couldn’t see that they made high energy versions
Edited by timmy850, 11 July 2024 - 12:12 PM.
#13 Robbie224
Robbie224
  • 28 posts
Posted 11 July 2024 - 12:15 PM
It the silver 0.8 oms . I learnt about correct coils for high power ignition watch ac Dodd videos
#14 Robbie224
Robbie224
  • 28 posts
Posted 11 July 2024 - 12:18 PM
Pass about accuspark. It was rolling road turned have original points rolling road operatal fitted accuspark and set plugs to 35
#15 Robbie224
Robbie224
  • 28 posts
Posted 11 July 2024 - 12:19 PM
It running a 1300gt engine
