It running a 1300gt engine
Electronic Distributor
Robbie224
, Jul 08 2024 09:54 AM
18 replies to this topic
#16
Posted 11 July 2024 - 12:20 PM
#17
Posted 11 July 2024 - 12:52 PM
What exact module is it? The modules which fit into a points distributor aren't usually designed for a 0.8 ohm coil.
#18
Posted 11 July 2024 - 12:53 PM
I didn’t think Accuspark made any modules that are rated to fire a 0.8ohm coil.
A 0.8 ohm coil requires a lot more current (than a 1.5 ohm or 3 ohm coil) and will overheat the module pretty quick
Powerspark make a high energy unit, it has a four sided magnetic trigger wheel and a different module
IMG_0920.jpeg 27.71K
0 downloads
Compared to the standard Accuspark which has a slip on plastic ring with magnets
IMG_0921.jpeg 30.9K
0 downloads
Edited by timmy850, 11 July 2024 - 12:55 PM.
#19
Posted 11 July 2024 - 06:10 PM
Another option here is to get in touch with Martin at Distributor Doctor. If he can't sort what you need, it can't be done.
https://www.distributordoctor.com/
