Sometimes, Too Hot. Rad O Electric Fan ?
Posted 30 July 2024 - 02:24 PM
The engine reaches the optimal working temperature (90°C) very soon. But the heat is overwhelming like these summer days, the needle easily goes to 100/120 degrees as soon as you are stopped.
The car;a 1972 Austin Mini, now 1310cc, double S.u Hs2 carb and standar radiator with 11blades yellow plastic fan.
Wich would be the best option to improve the cooling?
The super two cores radiator (C-ARA4443) like Minispares advise me, or an electro fan in the wing prepared "just"to cool as soon as the temperature goes above 90 degrees?
Kind regards
Luis
Posted 30 July 2024 - 03:07 PM
Posted 30 July 2024 - 03:23 PM
I would check the engine tune before anything else.Steve..
bad positioned dizzy?
Posted 30 July 2024 - 03:50 PM
Even Rover fitted an additional electric fan under the wheelarch to the later 1275cc & Cooper Minis in the end. Back in the day I nearly always had to put the heater and blower fan on in slow moving traffic queues on a hot day in the UK, especially with a modified engine spec. Since fitting a Rover Cooper electric fan and a manual switch I can keep the temp gauge around normal no problem.
This is the Rover Mini SPi electric fan which is pretty easy to fit under the wheel arch of an earlier Mini by just drilling 3 holes in the inner wing and I think i added some small spacers to the support mounting legs as the SPi has a large hole cut out for the fan blades to sit in closer to the radiator.
Minispares:-
"This radiator electric fan was fitted as standard on minis with the large round hole cut out in the inner wing fron 1991 on the last carb models through to the SPI but there was an earler type which is no longer available that was on earlier 1275 cooper carb models." (RSP Cooper)
http://www.minispare...c/PGG10058.aspx
Posted 30 July 2024 - 04:26 PM
One simple thing... is the fan the correct way round?
Posted 30 July 2024 - 05:53 PM
Of course, that's the first rule. "ENGINE SIDE" leyend, opposite to radiator. But thank you for your help.
Posted 30 July 2024 - 06:00 PM
Timing correct?
mixture correct?
don’t use an alloy radiator.
dont use too much antifreeze/rust inhibitor mix as it reduces the ability of the liquid to transfer heat.
Posted 30 July 2024 - 06:10 PM
Another thought is to fit an aftermarket secondary (electric) fan. I fitted an ebay special to my minis, with a manual switch on the dash, total cost was around £30 all in (wire, crimp on terminals, and the switch)
Posted 30 July 2024 - 08:12 PM
Even Rover fitted an additional electric fan under the wheelarch to the later 1275cc & Cooper Minis ...
Thanks a lot mab01! The electric fan is a possibility, but after the correct timing and when discard a new radiator.
Posted 30 July 2024 - 08:14 PM
-Mixture? Close to the light brown color and I continue adjusting.
-Radiator? Copper (standard).
-Antifreeze? Inorganic Krafft 50% (I want to put Mercedes blue on it, much more expensive.
Edited by PACINO, 30 July 2024 - 09:36 PM.
Posted 30 July 2024 - 08:49 PM
Posted 30 July 2024 - 08:58 PM
-Timing? Not sure it's on point, but very close. I've this pending.
-Antifreeze? Inorganic Krafft 50% (I want to put Mercedes blue on it, much more expensive).
https://i.ibb.co/rd9...descarga-4.webp
Link does not work. Try Imgur
Posted 30 July 2024 - 09:04 PM
If I'm reading the charts correctly, 50/50 glycol/water is about 35% more viscous than 30/70 (at typical engine temps). It also has a few percent lower heat-carrying capacity. Upshot is that the more concentrated stuff circulates more slowly and moves heat less effectively. The figures can be had from here: https://www.engineer...ycol-d_146.html
I found out years ago that this makes a useful difference to cooling. On a kit-car with a tired old Pinto and an even tired-er old radiator in it - with 50/50 mix it would often overheat. With 30/70 it ran fine.
So unless you really need the antifreeze to be 50%, try 30% instead. Might make all the difference.
Posted 30 July 2024 - 09:32 PM
Posted 30 July 2024 - 10:25 PM
Well well well, maybe you're right. I've been looking for my old 5L antifreeze container used before my engine's restauration, and it is 30%.
Maybe there is the issue.
