Solid State Fuel Pump
Posted 17 August 2024 - 08:49 PM
I wired it up and when I turn the ignition on, the pump seems to run constantly. Is this normal or is it a sign of a leak in the system?
Posted 17 August 2024 - 08:51 PM
Facet or a Facet copy ? Yes, that is what they do.
Posted 17 August 2024 - 08:56 PM
Posted 18 August 2024 - 01:52 AM
Posted 18 August 2024 - 08:33 AM
Fit an Ecco one from Fuelflow. They behave like the old SU pump. Only hear a ticking when it's actually pumping. Been using them for years. Made in NZ.
https://simonbbc.com...r-installation/
Posted 18 August 2024 - 09:27 AM
Posted 18 August 2024 - 10:05 AM
Thanks for the feedback. I'll look into other options at a later stage. For now I just needed something quickly and that works. It was cheap enough at the local auto parts place so happy with it for now. I'll just mount it on some rubber mounts.
Make sure it's not running at more than 3 psi, which is what SU and the Ecco pump run at otherwise you'll probably need a pressure regulator.
Posted 18 August 2024 - 10:46 AM
Posted 18 August 2024 - 01:51 PM
The pump I have says 0.03mpa which is just over 4psi
Posted 19 August 2024 - 02:51 AM
Pressure regulators can cause more problems than they fix.
Posted 19 August 2024 - 05:20 AM
Posted 30 October 2024 - 11:40 AM
I haven't seen petrol leaking out the bottom of the pump though.
Instead of the cube electronic fuel pump I tried previously, I got a Huco pump rated at 0.25bar at the pump.
I'm hoping this will be OK with the twin hs2 carbs.
Anyone else use the Huco 443000 fuel pump? I chatted to a guy locally who uses it on his mini with a hs4 without issues.
Posted 30 October 2024 - 04:44 PM
Posted 30 October 2024 - 11:24 PM
If I remember correctly, at one point you had fuel leaking from the manifold? That would've also filled the sump with some petrol.
I'm wondering if something as simple as an inline fuel tap can successfully reduce fuel pressure. Anyone tried it?
That won't work.
It could reduce the pressure when there's flow though. It is a restriction and the pressure drop will vary depending on the flow rate. when the float bowl is full, the full pressure will still occur.
Edited by 68+86auto, 30 October 2024 - 11:30 PM.
Posted 31 October 2024 - 05:29 AM
Ahhh, yes correct. Though I checked the oil after that and if there was petrol in there, it wasn't as obvious as it now.
That won't work.
OK, thanks, makes sense. So a pressure regulator has a chamber that hold fuel before it gets sent to the carbs at a consist and reduced pressure?
