Fitting 1275GT clocks
Posted 20 November 2006 - 11:37 PM
My mini is a 1275spi sprite from 1995 with 12" wheels on it.
Will i need to alter wiring to fit these clocks or will they be straight swap apart from revcounter. will they need recalibrating and can anything be done about millage.
sorry bout million questions
thanks Lee
Posted 21 November 2006 - 12:29 AM
http://www.theminifo...showtopic=34182
there is another type of clocks that only has 1 spade terminal and 1 bullet terminal!! this will go straight in your car as the black/white and orange/green wires are already in your loom!!
Posted 21 November 2006 - 06:45 PM
Posted 21 November 2006 - 06:57 PM
Now it’s just a case of bolting in the new 3 clock cadge to the bulkhead and plugging the clocks up and bolting them to the cadge.
As for wiring up the rev counter, there should all ready be two spare wires (regardless of weather or not it had a rev counter fitted to start off with) tucked behind the clocks with the relevant connectors already present.
Edited by 1984mini25, 21 November 2006 - 06:57 PM.
Posted 21 November 2006 - 07:09 PM
I also have a sneaky feeling that the multi plug on the back is different, as yours is a SPI, or maybe that's just MPI's... dunno try not to get involved with voodoo injection minis
Posted 21 November 2006 - 07:30 PM
but if you use the old spedo from the 2 clock set up you don't need to change the cable as the corect one is already fitted.Another issue is you will need to change the speedo cable from a nippon variant to the smiths one..
Also the gt clocks read upto 120mph which would mean the spedo drive in the gear box would be alsobe wrong as well.
Edited by 1984mini25, 21 November 2006 - 07:30 PM.
Posted 21 November 2006 - 07:38 PM
As for the speedo reading right, that'll all depend on the FD which is currently in the car. GT clocks are designed for 12" wheels running a 3.4 FD, or if you have the realy early ones, 10" wheels running a 3.4 or 3.6 FD
The only way to find out is to work out the TPM of both speedo mechanism and then make the adjustment in the gearbox drive.
Posted 26 November 2006 - 05:45 PM
thanks again lee
oh and where do i get one of these connection kits to convert.
Posted 27 November 2006 - 02:53 AM
Posted 28 November 2006 - 06:11 PM
Posted 28 November 2006 - 07:15 PM
Posted 28 November 2006 - 07:29 PM
Posted 29 November 2006 - 01:30 AM
they shud all be in the earlier looms!! hope this helps!!
That is an old set, but the wire from the -ve side of the coil needs to be taken through the tacho and then back to the dizzy, the wire which is in the loom is for the later signal type tacho's, this is a loop one.
thats so much easier an explaination then mine!! i'm always overcomplicated!!
Posted 29 November 2006 - 03:10 PM
Posted 29 November 2006 - 06:13 PM
not sure how well this type of clock will work with the later ignition types!! mite not read very well til the revs come up over 3000rpm!!
