In my experience Mini (A series) head gaskets rarely fail unless a few things have come in to play...
1) Poorly fitting in the first place, this includes cheap gaskets, incorrectly torqued head nuts, warped head inferior bolts etc etc
2) Abused in use, ie run with inadequate cooling ending in a massive over heated engine.
Assuming none of the above, how long has the engine been running without any issues.
Though those readings are low, I would suspect other issues, like total lack of maintenance, including the ignition system, but of course I am guessing
You say the readings are low. What would you expect?
There's further info in my reply below.
Thanks for sharing your knowledge and experience.
Peter
I like to see around 160 PSI, but this come with a good few caveats, not necessarily a complete list
1) Mileage
2) Throttle held wide open
3) Fully charged battery
4) All plugs removed
5) Engine hot and oil up to temperature
6) CAM dependent (Sportier CAMS will give lower PSI reading at cranking speeds)
7) Healthy starter motor
He's done very few mils since the (re)build, we only turned it over until we got a reading on each cylinder, the battery is good/new, each cylinder was tested, one at a time, the engine was cool, he has a high lift cam and a Janspeed stage 3 head, hence the likely lower than expected readings?
Peter
If its very low mileage, back in the day "BMC" / "British Leyland" recommended a running in period of between 500 and 1000 miles. If this has not been done maybe the pistons rings have not fully bedded in yet
