Mini Spares Cooper S Block Castings
19 replies to this topic
#1 Spider
  • 15,245 posts
Posted 26 September 2024 - 06:59 AM
Been a while in the works but looks like these are really coming along
#2 MikeRotherham
MikeRotherham
  • 994 posts
Posted 26 September 2024 - 08:31 AM
Are these cast in the UK?
#3 Spider
  • 15,245 posts
Posted 26 September 2024 - 09:07 AM
I believe they are.
#4 DeadSquare
DeadSquare
  • 3,214 posts
Posted 26 September 2024 - 11:28 AM
I wonder if the bore centres are the same as original, or if they have eased them apart.
#5 IronmanG
IronmanG
  • 1,283 posts
  • Local Club: Box hill. Lsmoc member
Posted 26 September 2024 - 02:11 PM
I was thinking exactly the same. Being able to get a 1380 but have more meat
#6 stuart bowes
stuart bowes
  • 2,287 posts
Posted 26 September 2024 - 02:24 PM
this is probably a really stupid question but don't they have to line up with the crank journals though?  can you just move them a bit left and right and it still works ?
#7 PoolGuy
PoolGuy
  • 867 posts
Posted 26 September 2024 - 02:26 PM
I suppose that could depend on MS wanting them to be usable for historic racing or not?
#8 absx2
absx2
  • 932 posts
Posted 26 September 2024 - 02:48 PM
There`s a decent bit of wiggle room on the Gudgeon pins ( wrist pins ) to compensate for offset bores so it wouldn`t be a problem.
The crank journals stay exactly the same as only the pistons are moved across.
#9 DeadSquare
DeadSquare
  • 3,214 posts
Posted 26 September 2024 - 03:05 PM
848 rods are offset because the bores are not over the crank pins.  When I bored an 848 out to 68.25MM, I moved the bores sideways and used S rods.
It wouldn't be much, a couple of MM for bore 2 & 3, and maybe 4MM for 1 & 4.  There is a bit of movement along the gudgeon pin and you could shave one side of the little end.
#10 Ethel
  • 26,170 posts
Posted 26 September 2024 - 03:21 PM
Wasn't there talk of making them for  one of the super sexy billet cranks? I might've dreamt that.
The money will be in motorsport, so they're likely made to comply with any class regulations
#11 Cooperman
  • 23,367 posts
Posted 26 September 2024 - 03:24 PM
How much will they cost?
#12 DeadSquare
DeadSquare
  • 3,214 posts
Posted 26 September 2024 - 04:15 PM
If you need to ask,  You can't afford one.
#13 Shooter63
Shooter63
  • 1,110 posts
Posted 26 September 2024 - 04:54 PM
The blocks are Appendix K compliant, have they added a bit of meat here and there? Yup they certainly have, I'm off to HQ on Saturday so I'll have a look at the price but I seem to remember they said around 2K when I asked before.
Shooter
#14 Gaz66
Gaz66
  • 981 posts
Posted 26 September 2024 - 05:39 PM
They are casting alloy race heads too. 👍
#15 Cooperman
  • 23,367 posts
Posted 26 September 2024 - 07:47 PM
Shooter
That would be extremely reasonable.
I actually have a spare thick-flange 'S' block, crank and rods which I keep as spares for my 'S'. However, if new blocks are available, I may rebuild my spares into a complete engine and sell it. I also have a 3-syncro gearbox casing which could be rebuilt and included. Now there's an idea!
