Can anyone see from the photos where its going wrong or offer any advice on how to get it to fit.
Bobby
Posted 02 October 2024 - 01:26 PM
Posted 02 October 2024 - 05:03 PM
Is this the original door ? what panels have you changed on the body ?
Edited by I hate Brian, 02 October 2024 - 05:04 PM.
Posted 02 October 2024 - 08:37 PM
Posted 02 October 2024 - 10:48 PM
Is it a "Genuine" skin?
Posted 03 October 2024 - 07:20 AM
Edited by BobbyMax, 03 October 2024 - 07:22 AM.
Posted 03 October 2024 - 11:58 AM
Hi all and thanks 4 joining in.Its a Heritage skin And the door is original one from car.
As for the pannels I've changed on this side, Inner, outer wing, and door step.
The wings were both heratage and the outer one had the A-panel allready attached. As for the door step that was magnum as it came with the car in a box of bits.
My comment will not be helpful, BUT: you should have involved the door in the process prior to welding in all these panels.
Now you'r up **** creek....
You can try to knock the lower A-panel edge further forward. Needs some skill thoug to not make the panel bulge out. Would have been easier again before welding the bottom A-panel edge.
On the rear you probably need to change the door panel beading (flatten, then re-bend). Have you checked and compared the left to right door aperture dimensions?
Glad I am not in your shoes
Posted 03 October 2024 - 02:35 PM
Edited by BobbyMax, 03 October 2024 - 02:36 PM.
Posted 04 October 2024 - 04:22 PM
Although it’s not of immediate help, spray some grey or white primer on the edges of the skin to get a better idea of what clearances there actually are.
Posted 04 October 2024 - 04:23 PM
Posted 04 October 2024 - 04:24 PM
Posted 04 October 2024 - 07:22 PM
I might be seeing it wrong but it looks like the frame part isn't too bad a fit, it's just the door skin is large at the moment because you haven't actually attached it and folded over the edges yet
when I compare my skins (heritage as well) to the frame, there is quite a lot of extra length at the bottom of the skin, like I could fold it tighter to the frame by about 10-15mm even. and that's up far enough to follow the lines of the car, i think
short version how much scope is there for just folding a lip over closer to the frame, at each side ( i say 'just' but obviously not a 5min easy job)
Edited by stuart bowes, 04 October 2024 - 07:24 PM.
Posted 06 October 2024 - 01:16 PM
Edited by BobbyMax, 06 October 2024 - 01:18 PM.
Posted 06 October 2024 - 02:05 PM
Posted 06 October 2024 - 04:48 PM
Posted 07 October 2024 - 08:56 PM
