Charge Fault ?
19 replies to this topic
#16 gaspen
gaspen
  • 1,002 posts
Posted 03 November 2024 - 11:37 AM
I'm waiting for the new brush set so I check what I can check on the alternator.
The Rectifier
I learnt that all 9 diodes should allow the voltage to flow only for one direction. I've measured them with a multimeter switched to diode test.
Diodes in circuit 2 and 3 are all the same (where the outputs are)  but circuit 1 flows in the opposite direction
Is it the normal operation ?
I'd need to look at one and a diagram to be sure but I guess it is fine.
If it's an original rectifier assembly then that should be fine, a diode wouldn't fail and reverse it's direction as far as I'm aware. If the readings are the same as the others but reversed, I say it's fine.
If it's a replacement part, who knows.
I bought a complete repair kit from ebay a while ago.
Regarding to the manual that circuit (1) will help "build-up" the magnetic field inside the alternator during start.
Attached File  Képkivágás.JPG   69.54K   0 downloads
#17 Designer
Designer
  • 647 posts
  • Local Club: LSMOC
Posted 04 November 2024 - 01:02 PM
Hi Gaspen
Well my brain due to age was reasonably muddled but having read the above it is now totally toasted.  :wacko:  :wacko:  :lol:  :lol:
Paddy
#18 gaspen
gaspen
  • 1,002 posts
Posted 04 November 2024 - 02:29 PM
Hi Gaspen
Paddy
This is why they installed a litte fan on the alternator  :D
#19 gaspen
gaspen
  • 1,002 posts
Posted 04 November 2024 - 05:09 PM
If you are intrested and don't want to import from UK this one is an alternative
Price ~1,50 EUR
Attached File  20241104_125011.jpg   70.74K   0 downloads
Edited by gaspen, 04 November 2024 - 06:10 PM.
#20 gaspen
gaspen
  • 1,002 posts
Posted 05 November 2024 - 11:08 AM
Job done  :proud:
Steady 14.33V at the alternator, 14.1V at the battery. The charge starts for a little throttle but it works
For test drive I'm going to the workplace the Mini
Attached File  20241105_095449.jpg   43.17K   0 downloads
