1974 Innocenti With A K20Z3
16 replies to this topic
#16 -Lost-
-Lost-
  • 22 posts
Posted 20 September 2026 - 12:38 AM
Next up is the shifter mounting.  I needed a grommet to feed the cables through the firewall and I found a nice one made by K-tuned, but it's kind of expensive.  It turns out there are a ton of knock-offs available on ebay, so I picked one up.  The holes go straight through, but my cables need to make a very tight turn and they didn't fit very well.  I made a new rubber insert with the holes angled about 45 degrees so the cables sit better.
First I trimmed my piece to the same size as the included one, then I built a wooden cage with an angled base to hold everything in place and keep the rubber from moving around while trying to cut it.  I put it in the vise and drilled a hole with a 3/8" brad point bit, then I made a punch out of 7/16" steel tubing to cut it to final size.  Results aren't perfect, but certainly good enough since it's not a part you can really see easily.
#17 bruce_rob
bruce_rob
  • 37 posts
Posted 13 October 2026 - 01:10 PM
Nice work, This is going to be awesome when its all done
