As I’ve now chilled off all that rubber/tar C**p from my minis floors, but as the black tar stuff was laid straight over the top of the metal drain plugs (can’t really se the point of them if there covered) it did a pretty good job of holding them in place. So I’m now going to replace all of the metal plugs with the rubber type that do a much better job of sealing and staying put.
Only (yep there’s always but) when I had a look in chavspeed (aka Halfords) the only ones I could find were 3 in a box of about 30 other rubber grommets and plugs for £4.50, witch as I need about 15 (two for spare wheel well in the boot as well) of the ruddy things would work needing 5 boxes at just over £20.
Which I though was a little on the pricey side for some little 1” rubber plugs and 5 boxes of a load of others I will probably never ever use.
So does anyone know of somewhere else that I could purchase about 15-20 (might be worth having a few spare) of these rubber plugs to fit a 1” diameter hole?
As I can’t start gluing down my under felt / sound proofing (yes I know minis aren’t meant to be quite) till all these holes are plugged.
Cheers,
Rubber plugs for holes in floor pans
1984mini25
, Nov 21 2006 06:07 PM
6 replies to this topic
Posted 21 November 2006 - 06:07 PM
Posted 21 November 2006 - 06:11 PM
Are these just rubber gromits that are sealed rather than having a hole through the middle?
Posted 21 November 2006 - 06:13 PM
yes
Posted 21 November 2006 - 06:24 PM
not sure of the size but cpc sell them by the 100 for less than a tenner
http://cpc.farnell.c...equestid=941057
how about the ones on this page.
http://rswww.com/cgi...r...gondhgh.0
Posted 21 November 2006 - 07:00 PM
i dont know the size but you could try a electrical wholesalers
Posted 21 November 2006 - 07:40 PM
i got mine from minispares part no: 14a7081 they are genuine too.
Edited by mikecmini, 21 November 2006 - 07:41 PM.
Posted 21 November 2006 - 07:41 PM
yeah maplins do em i think
