I'm thinking about fitting new shock absorbers (lowered). Which one do you think is better? Sensations, Soft/hard.
Thanks in advance!
Posted 02 December 2024 - 07:50 AM
Are you after comfort or all out road holding ?
If you don`t push the limits of your car and would like a comfortable ride just fit a set of standard Kayaba shocks.
A fully adjustable unit gives you everything and although not what you asked for Protech shocks are probably the best out there.
Posted 02 December 2024 - 07:57 AM
another vote for Protech's as so easy to adjust, the Koni's cant be adjusted as easily
Posted 02 December 2024 - 02:25 PM
spax?
Edited by mvahora, 02 December 2024 - 02:25 PM.
Posted 02 December 2024 - 02:42 PM
spax?
Posted 02 December 2024 - 02:46 PM
Edited by Cooperman, 02 December 2024 - 02:46 PM.
Posted 02 December 2024 - 04:48 PM
I did have Spax on two cars but they both squeak which is very noticeable inside the car when rolling down the road, okay on a competition car but irritating on a road car as it sounds like rusty bed springs to the point I removed them from the road car and fitted KYB Gas-A-Just followed by Protech .
The Gas-A-Just were actually very good on the road but when pushed really hard they weren't quite up to the job compared to the Spax but on a sensibly driven road car they`re fine.
Posted 02 December 2024 - 05:27 PM
Posted 02 December 2024 - 10:49 PM
Posted 03 December 2024 - 01:23 PM
the ones with springs aren't just shocks are they, they're coilovers
which you don't need or want as has been discussed recently https://www.theminif...and-suspension/
Posted 03 December 2024 - 01:26 PM
Posted 03 December 2024 - 04:21 PM
Edited by and90cooper, 03 December 2024 - 04:22 PM.
Posted 03 December 2024 - 05:33 PM
Cheers Stuart! I've read all the hilo. What seems increíble that no one like the coilovers, I mean ...the spring ones. My rubber cones are from MiniSport desing by Moulton, and I installed It in 2010. I don't fit new ones at the moment. For me it was a hard job. So...if I buy something, Will be a Protech or GAZ dampers. Lowered ones.the ones with springs aren't just shocks are they, they're coilovers
