Which Vacuum Guage?
49 replies to this topic
#46 Rubbershorts
Rubbershorts
  • 377 posts
Posted 27 December 2024 - 06:39 PM
I have a spare MS spacer with the barb/nipple on it if you need (you can take it out and fit it you your spacer?) - I bought it for exactly the same reason and it was too thin.  I fortunately had the nipple on the HS4 so just used that for the vacuum gauge.
Hi David, I've sent you a message. Daz.
#47 gazza82
gazza82
  • 3,021 posts
  • Local Club: TMF+
Posted 27 December 2024 - 07:04 PM
You can get thicker spacers with the adaptor fitted.
Thanks Gazza. Deleted my first answer as I mis read your answer. I'm struggling to find anything apart from the Minispares offering.
This one?
https://www.minispar...vacuum-take-off
#48 Rubbershorts
Rubbershorts
  • 377 posts
Posted 27 December 2024 - 07:29 PM
This one?
That's the one I was looking at. It's too thin unfortunately.
#49 timmy850
timmy850
  • 3,391 posts
  • Local Club: MITG
Posted 27 December 2024 - 11:03 PM
You can drill and tap the manifold or a different spacer and add the vacuum port.
It might give better results in the spacer or the manifold compared to using a vacuum port right near the throttle blade
This is an example - the manifolds have a 5/8unf port for the booster, you can get an adapter like this to a barb fitting
https://www.hampdon....to-male-adaptor
#50 miniGTS
miniGTS
  • 254 posts
Posted 10 February 2025 - 02:32 PM
I connected one of those big vacuum gauges to the inlet manifold (Twin SU HS2) to see what readings I get.
At 1000rpm idle it bounces quite fast between between 5 and 10 (in Hg Vac) which according to the gauge markings is late valve timing or leak at the intake.
Then taking revs up to between 2 and 3000rpm it goes to 15 and sits there fairly steady so that suggests late ignition timing.
Anything over 3000rpm it sits steady in the normal motor range.
Any suggestions for how I should address these timing issues?
I don't know what cam is in there (and don't have the tools to check), the igition timing is set to 10dgrees at 1000rpm. I have an accuspark electronic ignition in a 45D distributor and the centrifugal advance is stamped with 11. All the 45D distributors I have is 11 so I assume those were standard on the mini in SA.
