Can I Use This Head Like This?
19 replies to this topic
#16 Lplus
Lplus
  • 1,004 posts
Posted 10 January 2025 - 05:50 PM
Here's the head now. I'm wondering whether it's best practice to chamfer the waterway holes to take the sharpness off them. I did run a small file around the chambers to take the sharp edge of them.
No, just leave them alone.
#17 Shooter63
Shooter63
  • 1,299 posts
Posted 11 January 2025 - 03:33 PM
I've been doing a bit of rooting about regarding you piston dish, are you sure you have 8.3cc? This seems high, and I can't find that listed anywhere, compression ratio yes, but not piston dish?
Shooter
#18 babsbrown
babsbrown
  • 592 posts
Posted 11 January 2025 - 11:31 PM
Shooter
Hi shooter, well I wrote that down from using syringes to cc them. So I could have quite easily have over calculated. I did notice the higher 1098 compression pistons had 7cc dishes. I'm hoping they're closer to those really.
Bit of a shame as theyre in the block now so I would be able to accurately measure them.
Cheers again,
#19 Turbo Phil
Turbo Phil
  • 2,427 posts
Posted 12 January 2025 - 05:58 PM
Yes definitely worth running a file around all the chambers & holes after it’s been skimmed. Removing the sharp edge will reduce the chances of a crack starting.
Phil.
#20 babsbrown
babsbrown
  • 592 posts
Posted 12 January 2025 - 07:52 PM
Thanks mate, would you glance the holes with a countersink bit or just a small file? Cheers
Phil.
