Front Right Wheel Play
16 replies to this topic
#16 Ethel
  • 26,717 posts
Posted 10 August 2026 - 10:31 PM
That was the point I was trying to make.By looking at 2 components side by side it should be easier to detect  movement between then, either by feeling movement under a finger or with feeler blades in gaps you can  widen or close.
#17 Spider
  • 15,793 posts
Posted 11 August 2026 - 07:24 AM
If it's getting tight and loose spots while rotating the drive flange then the bearing is damaged or out of round. The bearing can be distorted by the hub if that's out of round, though I'd say, it has play all round, only that you are able to feel it in one or two places due to the grease in the bearing.
Slightly different point here, if you are getting any play in the Drive Flange and CV and the nut is torqued up, then it can only be the bearing and / or the hub. There's normally 0.004 - 0.006" pre-load on the bearings, so something does need to be quite worn before it can be felt.
