To answer "On The Road" yes i mean the steps in the Choke button that has 3 notches.
Major breakthrough this afternoon.
I noticed that the choke cable to the lever was really slack so I adjusted it.
I pulled the lever up until the Jet Body just started to move and nipped up the wire at that point.
This meant that the car would tick over normally with the choke being full pushed home.
I guess there might be another way to set up the jet body so it is in a better setup than relying on the cable tension setting
I checked the timing again and as it was out a couple of degrees.
I even took the car for a quick run around the block.
It was a bit lumpy so there is more to look into but feel
