Boot Floor Repairs - Looking For Advice
12 replies to this topic
#1 WillBriggs
WillBriggs
  • 16 posts
Posted 16 March 2025 - 07:49 PM
Hello all,
I am looking for a little bit of advice on boot floor repairs. I recently took my mini for a Pre-MOT check at a local garage, and they flagged that it had a couple of holes near the rear subframe bolts. I took it back home and started poking around. I found 2 metal plates that have been glued over some rust & holes, then fibreglassed, filled and painted again.
I am looking to repair this section myself, and noticed that various online mini parts shops sell repair sections of the boot floor. From the photos attached, do you think that a repair section will do the job?
Thanks in advance :)
#2 Gaz66
Gaz66
  • 1,193 posts
Posted 16 March 2025 - 09:25 PM
That rear section is available as a repair panel and covers the full width of the boot floor and approx 10" into the boot.
#3 WillBriggs
WillBriggs
  • 16 posts
Posted 16 March 2025 - 09:27 PM
I was looking at those earlier. In terms of welding it, would you leave a 1inch overlap and plug weld?
#4 sonscar
sonscar
  • 3,256 posts
Posted 16 March 2025 - 09:37 PM
It would need to be continuously welded,how do you intend to approach the valance seam?.Tricky repair to keep from project creep.Steve..
#5 mab01uk
mab01uk
  • 13,082 posts
Posted 16 March 2025 - 11:37 PM
The Mini-Machine catalogue has lots of useful boot floor repair panels:-
https://www.m-machin...s catalogue.pdf
M-Machine website:-
http://preview.m-machine.co.uk/
Edited by mab01uk, 16 March 2025 - 11:38 PM.
#6 slidehammer
slidehammer
  • 1,212 posts
  • Local Club: LSMOC
Posted 17 March 2025 - 05:11 PM
I would go for the rear boot floor repair panel, the fit isn't brilliant but with a bit of work is fine. The tricky bit is separating the rear bumper seam which is 3 panels thick, valence, boot floor and boot aperture. I would expect to find more rust once you start digging, I am afraid.
#7 stuart bowes
stuart bowes
  • 2,638 posts
Posted 17 March 2025 - 05:59 PM
the bottom edge of the rear panel doesn't look too great either, I'd start with the cheapest simplest job first, clear out the boot, including removal of tank obviously, cable tie all the wiring up out of the way and spend a day in there with a few wire brush drill attachments, clean up all round and keep going till you're seeing at least an inch or so of good metal in all directions, see what that looks like and go from there
(goggles and mask, obvs)
Edited by stuart bowes, 17 March 2025 - 06:05 PM.
#8 Gaz66
Gaz66
  • 1,193 posts
Posted 17 March 2025 - 06:07 PM
You'll probably find the hinge panel is toast too when you start poking about.
This may sound bad but actually simplifies the boot repair as you can fit the lot in one go along with a valance 👍
Edited by Gaz66, 17 March 2025 - 06:08 PM.
#9 Stu1961
Stu1961
  • 646 posts
  • Local Club: Still Looking
Posted 17 March 2025 - 07:28 PM
I had very similar issues in that area, ended up using the left and right hand repair panels from Mini-Machine, they are an excellent fit.
You may find the rear valance closure panels will need replacing as well as they seem to rot from the inside out, and just for good measure I replaced the rear valance with a Heritage one.
This my personal opinion and worked for me but when it came to tackling the rear panel I used the one that goes up to and includes the lower edge of the rear screen instead of the other option that cuts through the boot opening, overall finishing of was so much easier and it guarantees the boot lid will fit correctly.
Lastly resist removing the rear panel until the boot floor is all completed as I found it acts as a perfect datum.
#10 WillBriggs
WillBriggs
  • 16 posts
Posted 18 March 2025 - 08:17 AM
Okay - My plan was to cut out the valance, then grind down the seam until it's just the boot aperture seam left - then spot or plug weld a new valance, boot floor repair section and the boot aperture back together.
Good shout, thanks for the advice - yep, I expect to find more :( I've been a few videos of people using the repair panels, and they had to shape them quite a bit.
Good shout, thanks for the advice - I've only got a small wire brush attachment for the drill at the moment, but I'll order a flappy wheel for the grinder and do this before ordering any replacement panels.
Really helpful, thanks for the advice Stu :)
#11 sonscar
sonscar
  • 3,256 posts
Posted 18 March 2025 - 08:35 AM
There are three layers at the flange.Remove the valance and boot floor and if possible try to salvage the top hinge panel flange to drill through and plug weld the repair.The joint to the boot floor has to be continuously welded for MOT.Easy but tedious fix.Enjoy.Steve..
#12 WillBriggs
WillBriggs
  • 16 posts
Posted 18 March 2025 - 08:54 AM
Thanks for the advice Steve, you've confirmed what I had in mind  :proud: !
#13 Cooperman
  • 23,569 posts
Posted 21 March 2025 - 12:36 PM
Actually, once everything is stripped out and the rusty bits completely cut away, it's easier than it looks.
I don't have a spot welder, so when I am attaching the new rear valence, boot floor and hinge panel replacement section, I drill the boot floor with 8 mm holes about 30 mm apart, then match the hole positions onto the hinge panel flange and drill those holes at 6 mm. That way the MIG welds 'grab' all three layers properly.
The seam welding across the front edge if the boot floor repair panel is, as already said, easy, but tedious. I do the full seam inside the boot with tack welds on the underside about 30 mm apart. Then seam seal on the outside before coating with bitumen or whatever you choose to use.
