Voltage Regulator Repair
30 replies to this topic
#16 gaspen
gaspen
  • 972 posts
Posted 01 April 2025 - 06:45 PM
For polarising the dynamo I will need a battery or any other DC 12V supply is enough ?
#17 gaspen
gaspen
  • 972 posts
Posted 08 April 2025 - 07:59 AM
Fit a DVR3. I did and all your problems go away.
https://dynamoregula...m/products.html
Which one should I choose ?  Could I load this old dynamo with 22 amps ?
#18 floormanager
floormanager
  • 711 posts
  • Local Club: Mini Club Sussex
Posted 08 April 2025 - 06:16 PM
<script type='text/javascript' src='https://www.theminif...f_vcYADv8-PPg=='></script>
Yes, 22amp one.  They are supplied both positive and negative earth, so make sure you specify the one you want.
#19 gaspen
gaspen
  • 972 posts
Posted 09 April 2025 - 10:53 AM
Do you installed one ? Any picture how it is fit ?
#20 floormanager
floormanager
  • 711 posts
Posted 09 April 2025 - 05:13 PM
Here’s some.  I put an inline fuse in for safety
Attached File  IMG_7452.jpg   48.17K   2 downloads
Attached File  IMG_7453.jpg   45.76K   1 downloads
Attached File  IMG_7454.jpg   50.3K   1 downloads
Edited by floormanager, 09 April 2025 - 05:18 PM.
#21 gaspen
gaspen
  • 972 posts
Posted 09 April 2025 - 06:00 PM
Thanks a lot !
What is the value of the fuse ?
#22 floormanager
floormanager
  • 711 posts
Posted 10 April 2025 - 05:02 PM
25 amp
#23 gaspen
gaspen
  • 972 posts
Posted 11 April 2025 - 10:59 AM
25 amp
Ok, thanks again
I am thinking about to replace the filed coil also
Where can I found a good one ?
#24 floormanager
floormanager
  • 711 posts
Posted 11 April 2025 - 05:37 PM
The field coil in the dynamo? I did it too, not straightforward.  Getting the original screws out of the dynamo was a challenge.  I mullered the screws, so had to drill them out.  Once the field coils were fitted, the commutator would not go in.  I had to spread the field coils with an exhaust pipe spreader.  Great when they are fitted but a bit of a pain to do.
#25 68+86auto
68+86auto
  • 992 posts
  • Local Club: Queensland Mini Car Club
Posted 14 April 2025 - 05:50 AM
Two things to note:
- Use the correct type and size driver which will be pozidriv which is totally different to phillips. Most fasteners on a mini or anything British are pozidriv, NOT phillips. It's something that most people don't know.
- there's a special tool to undo these screws sicne they are so difficult.
Edited by 68+86auto, 14 April 2025 - 05:50 AM.
#26 floormanager
floormanager
  • 711 posts
Posted 14 April 2025 - 06:45 AM
Would love one of those tools!
#27 gaspen
gaspen
  • 972 posts
Posted 25 April 2025 - 08:15 AM
Anyone is in contact with him ?  www.dynamoregulator.com
I ordered and paid a DVR3 unit 2 weeks ago but response since then.
#28 gaspen
gaspen
  • 972 posts
Posted 23 May 2025 - 03:44 PM
Finally I received the DVR3 unit. It is manufactured nicely  :proud:
I will install it into a RB106 box. I should bridge the existing 'A' and 'A1' connection. I am right ?
Attached File  20250520_154624.jpg   37.94K   0 downloads
#29 gaspen
gaspen
  • 972 posts
Posted 02 July 2025 - 04:36 PM
I made the transplantation today  :proud:
Attached File  20250702_182617.jpg   42.62K   1 downloads
Attached File  20250702_182657.jpg   35.82K   1 downloads
#30 floormanager
floormanager
  • 711 posts
Posted Yesterday, 07:03 AM
Nice install!  I put it underneath so I'd get a bit of heat transfer to the car but yours is neater.
