Reamer Tool - Borrow/rent?
suspension
16 replies to this topic
#1 AlexB
AlexB
  • 52 posts
Posted 26 March 2025 - 05:40 PM
Hey guys
I need to do my radius arms - anyone got a reamer tool I can rent or borrow?
I'm based south or Reading, RG7.
Alex
#2 Tones61
Tones61
  • 433 posts
Posted 26 March 2025 - 06:13 PM
Ac dodd :-)
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,765 posts
Posted 26 March 2025 - 06:35 PM
Sorry I sold it as there was no demand.
Ac
#4 red81
red81
  • 53 posts
  • Local Club: Pembrokeshire Mini Club
Posted 26 March 2025 - 07:02 PM
I've got the same problem, need to do mine.  £160 mini spares is a lot and they state one tool per car, does that mean that the actual business end is only man enough for two cuts?  Alex perhaps we can split 50/50 if its not?
#5 Lplus
Lplus
  • 911 posts
Posted 26 March 2025 - 07:12 PM
That's just a quirk of the ordering process software.  The tool is reusable many times. :proud:
#6 alpder
alpder
  • 444 posts
  • Local Club: MCR
Posted 26 March 2025 - 07:32 PM
I'm in Pembs (nr Narberth) and have a s/h original Churchill 18G588 I picked up on ebay (for which I paid far too much, considering its condition).
It is properly beaten-up - several chips in the cutting edges - but it still did the job fine for me on two cars so far. You're welcome to drop by with the arms and run it through at my workbench.
#7 Ethel
  • 26,049 posts
Posted 26 March 2025 - 08:43 PM
You should be able to pick up a reamer for £20ish quid, but you'll need a means of centring it. I got a reamer long enough to pass right through the arm  & made up a bush to sit in place of the needle roller. I know others have adapted  a radius arm pin in to an extension for the nose of the reamer to run in the needle bearing.
#8 StefanMini
StefanMini
  • 87 posts
  • Local Club: M.S.C.N
Posted 26 March 2025 - 09:00 PM
Just go to a machine shop, they did mine a few years ago both for 40 euros. They did a perfect job!
#9 AlexB
AlexB
  • 52 posts
Posted 26 March 2025 - 09:03 PM
Thanks guys. Annoying it's so expenive isn't it.
I'll have a think about going halves, but I think a local machine shop may be easier.
#10 nicklouse
  • 18,679 posts
Posted 26 March 2025 - 09:20 PM
This is why I always suggest just buying exchange arms.
#11 gaspen
gaspen
  • 972 posts
Posted 27 March 2025 - 06:56 AM
This one is not from MS, but it is the same  :xxx:
Attached File  20241103_152211.jpg   56.23K   3 downloads
#12 greenwheels
greenwheels
  • 689 posts
  • Local Club: Mini Fixers
Posted 27 March 2025 - 11:19 AM
Quote from a post I made in 2012: -
"This must be the cheapest Radius Arm Reamer. It's made from a radius arm pin (http://www.minispare...id=36996&title=). Cut of one of the end threaded stub pieces flush then with a cutting disc in your angle grinder cut two grooves in the end lengthways about 1/2 inch long 1/16 deep to make like a cutting tool. Grind back the end to give the 'teeth' a cutting edge. On the other end lock on a couple of nuts, and there you have it. I'm sure you can work out how to use it.
I saw this on an autojumble stall at a Malvern show. The seller had welded a T bar on the end instead of just a couple of nuts. He said he was closing down his motorists accessory shop and he used to hire this out to people."
#13 MiniJosh92
MiniJosh92
  • 1,708 posts
Posted 27 March 2025 - 12:58 PM
I can do them if you want to stick them in a box and send them over to me
#14 AlexB
AlexB
  • 52 posts
Posted 27 March 2025 - 03:23 PM
That's really kind, thanks. How much do you want to do it?
I'll drop you a PM once my new bushes arrive =)
#15 Homersimpson
Homersimpson
  • 833 posts
Posted 30 March 2025 - 10:34 AM
Do you actually need to replace the bushes? In the many I've done over the years it was normally the pin that wore rather than the bush.
