Drum Brakes Or Discs
16 replies to this topic
#16 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 11 April 2025 - 10:26 PM
I found the performance was much the same with or without the servo. The difference for me was braking with just my big toe, or having to use my whole foot
#17 Lplus
Lplus
  • 990 posts
Posted 12 April 2025 - 07:52 AM
This.  Disc brakes small enough to fit a 10" wheel require far more line pressure than twin leading shoe drums to provide the equivalent retardation.  The 7" are even worse than the 7.5". Even the 8.4" discs needed a smaller bore front line master cylinder to increase line pressure per kg foot pressure, as provided by the yellow tag twin line master cylinder.when discs were fitted to 998s.
Personally, I prefer to fit a servo to reduce the load on my foot and keep the forces on the master cylinder and connections at the level the were designed for.
