Mini Indicators Problem
7 replies to this topic
#1 oldzimmer
oldzimmer
    Just On Tickover
  • 8 posts
Posted 11 April 2025 - 01:37 PM
Hi Guys
My 1982 998 mini HL the indicators work when ignition key is turned once , when starting engine there not working
Any ideas why
Hazards work when engine is running ?
#2 Ethel
  • 26,073 posts
Posted 12 April 2025 - 12:10 AM
Hazards should work with or without the ignition key. Indicators should work with the ignition on only.
Have you looked to see what the indicators are actually doing on the outside? Fuse box connections would be the easiest place to mess up.  Fitting the hazard switch connector upside down is possible too. It might do some of that.
https://www.theminif...s-covered-data/
#3 oldzimmer
oldzimmer
    Just On Tickover
  • 8 posts
Posted 12 April 2025 - 02:25 PM
Hi
Sorry might be confusing
Hazards work ok , with and without engine running , indicators only work when key turned on , as soon as engine is on , the indicators dont work .
regards
#4 Ethel
  • 26,073 posts
Posted 12 April 2025 - 03:22 PM
So the hazards work as they should.
Do the indicators work with the ignition light on, before the engine starts?
What's happening when the engine's running? The flasher unit can be sensitive to current & resistance, so look at all four (or six) lights. Are the lights on the dash doing anything?  Try the lot, illumination, high beam... do the ignition & oil light go out when the engine starts?
#5 bpirie1000
bpirie1000
  • Area Managers
  • 2,376 posts
  • Local Club: Amoc
Posted 12 April 2025 - 05:33 PM
Check what is printed on the flasher units.
Basically
21w x 4..... is for hazard lights.. as in 4 lights on all at same time.
21w x 2 +5w ... is for indicators... as in 2 lights on each side at one time...
#6 alpder
alpder
  • 444 posts
  • Local Club: MCR
Posted 12 April 2025 - 05:39 PM
While it is most likely to be a fault in the indicator unit itself, I'd suggest also measuring the volts at the battery with the engine running. Because if the alternator regulator has failed, it may be producing over-volts output, and the failure of the indicators could - just perhaps - be a symptom of this.
Over-volts would kill the battery, as well as causing rapid bulb failures, so best to rule it out. As I say, it's an unlikely cause but worth a check.
#7 oldzimmer
oldzimmer
    Just On Tickover
  • 8 posts
Posted 17 April 2025 - 12:45 PM
Hi Guys
Me Again re indicators issues. Where will i find a wireing diagram to download for this 1982 hl mini 998 .
Any help will be appreciated
Regards
#8 sonscar
sonscar
  • 3,046 posts
Posted 17 April 2025 - 05:47 PM
Try the top of the technical section,labeled wiring diagrams.Steve..
