Unable To Lean Out Twin Hs2S
43 replies to this topic
#31 petey81
petey81
  • 1,331 posts
Posted 24 April 2025 - 02:42 PM
I've completed more checks today and have noticed lots of air in the fuel filter. Is this normal? Could it be the fuel pump?
#32 Lplus
Lplus
  • 904 posts
Posted 24 April 2025 - 03:49 PM
It's normal unless the filter is set up so the exit is right at the top so any air rises to the top and gets out.  Besides which i don't see how air could make it richer.
#33 petey81
petey81
  • 1,331 posts
Posted 24 April 2025 - 03:57 PM
I was thinking air leak around the fuel pump gasket? I'm clutching at straws to be honest and I am a week away from taking out the engine.
Or even if the head gasket was a poor quality one which going by the gasket number it isn't.
Oh and I've even fitted leaner needles which I had lying around which made zero difference
I have fitted a head gasket set supplied for a morris mini small bore. I'm sure these are the same??? If not...
Edited by petey81, 24 April 2025 - 05:40 PM.
#34 mrmeds
mrmeds
  • 250 posts
Posted 24 April 2025 - 07:54 PM
I had stick choke on mine -onLy found out too late - after finally getting the local twin carn expert to look. Hadn't rwalised how badly ovefuelling th engine was getting -until bits came out of with an oil change :(
#35 petey81
petey81
  • 1,331 posts
Posted 24 April 2025 - 08:00 PM
It definitely isn't a stuck choke 👍
#36 petey81
petey81
  • 1,331 posts
Posted 25 April 2025 - 03:33 PM
I have decided to remove the head. I have a victor HG arriving tomorrow so I will see if that makes a difference. I didn't notice any damage or any difference regarding the combustion areas or oil coolant holes. Bores look ok but the pistons and valves are cacked in soot! All removed in 40 minutes which is a record for me 😂
Edited by petey81, 25 April 2025 - 07:10 PM.
#37 stuart bowes
stuart bowes
  • 2,121 posts
Posted 25 April 2025 - 07:01 PM
What's the history on the new head then anyway, what type / work done / was it tested for cracks etc
#38 petey81
petey81
  • 1,331 posts
Posted 25 April 2025 - 07:08 PM
It was a refurbished head from a English car specialist.... and is a 12g202 head, I haven't sent off the old one with double springs so if it doesn't resolve I will put single springs on that head and send that one I have on the car now back to them.
Edited by petey81, 25 April 2025 - 07:26 PM.
#39 petey81
petey81
  • 1,331 posts
Posted 26 April 2025 - 07:07 PM
Still no luck. I guess it's the carbs or jets. I will try and borrow a carb and eliminate that.
I have tried everything!!
#40 Earwax
Earwax
  • 488 posts
Posted 26 April 2025 - 11:11 PM
About this stage in the process, you have to ask yourself why you love the mini.  I feel your pain Petey81, but   keep a clear head, be thorough and logical in your thought patterns and with persistence and you will sort it. For me after a long and generally interrupted ( days between efforts) process - I get mixed up and so rely on a whiteboard to cross off the various combinations tried always trying to isolate and change just one variable at a time
#41 petey81
petey81
  • 1,331 posts
Posted 27 April 2025 - 05:35 AM
Thank you for this.
I took some of my problem solving from work and mapped out everything I've checked changed or need to look at. One thing I haven't checked is the needle orientation in the damper ie not pushed too far in.
#42 petey81
petey81
  • 1,331 posts
Posted 27 April 2025 - 09:15 AM
I feel like an idiot!!! The needles were pushed all the way in 😔 I'm idling at 13.9
All sorted and thank you for everyone's patience. At least it hasn't cost me anything!
#43 imack
imack
  • 2,110 posts
Posted 27 April 2025 - 10:30 AM
How had they moved if nothing had been touched? If the screws had come loose the needles would drop or fall out (I had that once on hs4's) not move up.
#44 petey81
petey81
  • 1,331 posts
Posted 27 April 2025 - 10:43 AM
I'm not sure to be honest. I might of had a moment where I checked they were tight and pushed them up. (Even know I tried other needles!)
At least it's now sorted lol
I will learn from my mistakes
