Converting To Yellow Tag Brake Master Cylinder
brakes
7 replies to this topic
#1 Nickj270386
Nickj270386
    Just On Tickover
  • 8 posts
Posted 29 April 2025 - 09:25 PM
Hi guys I have a 1983 Mayfair you can no longer get the relevant brake master cylinder for this age vehicle so you have to fit the gmc227 (yellow tag) this is not a problem but anybody no what I have to do with the wiring for the master top,apparently you have to modify the wiring
Has anybody done this and have some more info
Thanks in advance
#2 Spider
  • 15,087 posts
Posted 30 April 2025 - 12:25 AM
Is this the Master Cylinder it was fitted with ?
https://www.minispar...quare-reservoir
#3 mbolt998
mbolt998
  • 404 posts
Posted 30 April 2025 - 06:54 AM
I did it by modifying the wires going into the back of the switch as follows:
https://www.theminif...need/?p=3765405
Other solutions are possible. Also make sure that the bottom section of the new MC goes to the rear brakes and the top to the fronts. It won't affect ultimate braking performance but will give you a much more natural feeling pedal (mine was wrong for years after an ignorant garage blah blah long story).
#4 coopertaz
coopertaz
  • 806 posts
  • Local Club: a-series-magpies
Posted 30 April 2025 - 11:17 AM
ignorant main dealer changed mine years ago and locks up the rears.
#5 Nickj270386
Nickj270386
    Just On Tickover
  • 8 posts
Posted 30 April 2025 - 09:43 PM
No not that one
#6 Spider
  • 15,087 posts
Posted 01 May 2025 - 06:01 AM
No not that one
Can you post a photo of what you have ?
#7 Ethel
  • 26,055 posts
Posted 01 May 2025 - 11:15 AM
The pressure failure sensors had continuity across both terminals* so pressing the brake warning switch showed the wiring was good.
The fluid level  float just makes the circuit if the float drops, hence the "dibber" sticking up through the lid that makes a better test than pressing the brake warning switch, that just tests the bulb when there's a float switch.
Join both wires at the master cylinder together & also connect them to one side of the float switch. Earth the other side.
* if there was a pressure failure the switch earthed itself via the master cylinder, lighting the bulb. The warning switch, also connected to earth when pressed.
#8 Nickj270386
Nickj270386
    Just On Tickover
  • 8 posts
Posted 01 May 2025 - 09:42 PM
That’s fantastic cheers mate
